AB adjustments behind plastic cover on Classic?
Schmoburger
So, under that cover panel on the Classic just above the power switch, there are what appear to be two unlabelled adjustable potentiometers or such on the analogue board... I've never known or particularly cared what they are for, but assumed they probably relate to display V- and H-position or some such thing, and now my curiosity has gotten the better of me and I must know. Anybody shed some light?
unity
Brightness is lower I think. Upper is either contrast or focus - I use it to sharpen the display.
unity
Yes, but its controlled via software anyway. So it more of a way to hardware set the max brightness.
Schmoburger
Yeh I can't see too many circumstances where the brightness would need to be hard-altered unless an actual compoonent was failing and causing the screen to dim... there seems to be plenty of brightness reserve left at the default halfway point. :)
