A/UX root & user partition name
beachycove
Dumb question, but here you go:
The default name for the main A/UX drive is "/". This for obvious reasons does not seem especially exciting. Can the drive name be changed to something else, say "HAL", "UNIX", or "Fink-Nottle", without causing a UNIX meltdown?
uyjulian
Why would you want to do that? That would cause a large confusion.
Do you want to want to type your paths as:
HALexample/path/
UNIXexample/path/
Fink-Nottleexample/path/
That is not how the POSIX standard works for absolute path. For absolute path, the path needs to start with 1-2 forward slashes.
You can change the name of the icon in the Finder without, apparently breaking things (I just tried).  It doesn't affect UNIX paths.
