The top plastic should help hold it in place. but ... they are normally a very snug fit.. for the Meow Toast Rev 2 the rev3 isn't as snug though...I bought several of these a month or so ago, but have only installed one. I noticed that it's a bit wobbly side-to-side when installed. I wonder if any of those 3D printing gurus out there has a solution to make it sit in the socket supported...?
I am currently working Case for Pis that is also modeled after Mac Plus... after I Get that done I will see about making a clip for the meowToast Rev2/3The top plastic should help hold it in place. but ... they are normally a very snug fit.. for the Meow Toast Rev 2 the rev3 isn't as snug though...
LOL, I should have thought of that. It just didn't occur to me to put the original clip back on. I didn't think it would fit, but now that I look at it, It prolly fits like a glove. <facepalm>The top plastic should help hold it in place. but ... they are normally a very snug fit.. for the Meow Toast Rev 2 the rev3 isn't as snug though...
Dang! That is cool. I hope you share it when you're done. I assume you've got a specific size LCD screen in mind... I'm very interested. I even had a friend print me out this Make a tiny Mac from a Pi Zero instructable for me. It's cool, but the screen is sooooooo tiny it makes it un-usable for anyone over 40! LOLI am currently working Case for Pis that is also modeled after Mac Plus...
That tiny mac for the Pi Zero is where I got the idea... I wanted something a little easier to get screen wise. Then I wanted something slightly bigger but not to big as it is kind of a desk toy ... I Upgraded to a 3.5 inch screen... IT still isn't finalized I may go with a 4.3 or 5 inch screen.Dang! That is cool. I hope you share it when you're done. I assume you've got a specific size LCD screen in mind... I'm very interested. I even had a friend print me out this Make a tiny Mac from a Pi Zero instructable for me. It's cool, but the screen is sooooooo tiny it makes it un-usable for anyone over 40! LOL
That may happen I still need to get it to be an easily printable thing and I am working with another person to help make it so we have to decideSuperb! I don't want to completely hijack this thread. So the last thing I'll say is I would be interested in purchasing a case for one if it was platinum and looked like an SE/30!![]()
Nice I Hope you enjoy them.Got mine in the mail the other day -- look great! Got one installed in the IIci but haven't actually powered it on yetIt's been running without a battery at all for over a year - will be weird to see it retain its 32bit configuration!
The back of the PCB should have it written on it. It is CR2032 it is fairly small font, But I do also state in the description what it uses as well. I certainly want to make sure people do know what kind of battery. I hope this helps also thanks for the input.Got mine yesterday, very nice. One suggestion though, put the battery type on the PCB. Got to work with one in my pocket and ?????
Love the Plus Bezel LCD adapter. In a word: BEAUTIFUL!![]()
Oh yes those were the Rev3s I think it was an over site that they don't say CR2032... Thanks for letting me knowMine say meowTOAST at the top of the PCB with BetterBit lower left, GEEKY BIT lower right and no pretty purple to be seen.
edit: they're like the pic you posted for me:
