Can sombody tell me how my logic board looks? (Color classic)
Powerbook27364
I believe its this one. It is very close to caps and given that the grounding did not fix it, the caps nearby are certainly bad. Yours looks fine in terms of solder joints, so I wouldn't expect that the chip is bad.
3lectr1cPPC
I think you did a while back but it was post-recap - I can use it regardless but do you happen to have one pre-recap?
Powerbook27364
Unfortunately not. I bought the computer after it was restored and recapped, which is why I don't know if the mic board has been addressed.
