MrFahrenheit
I’m really looking for a solution that allows me to plug just a terminator into the logic board without any cable. I found this:
It says it’s pass through and has male and female ends. Does that mean it terminates regardless of which end is plugged in? I want to use the female end directly into the SCSI connector on the logic board of some Macs to terminate internal SCSI. Specifically I have found that they G3 beige logic board acts up when an external SCSI device is used without a terminator on the internal bus.
Thoughts please.
Alternatively I’d ask someone to make a PCB design and upload to GitHub, like this one, to be made by hand:
Internal SCSI Active Terminator IDC 50-pin Male to Female Pass-Thru | eBay
New, never used.
www.ebay.com
Thoughts please.
