Beige G3 Dual Monitors?
Nepnep
Hello all, and happy new year! I’ve decided to start messing with my Beige G3, which is quite an upgraded model with a sonnet 500mhz G4, ATi Rage 128 with a DVD decoder, and running MacOS 10.4 Tiger thanks to XPostFacto.
But that’s decides the point. I’ve had a spare Multiple Scan 14” display laying around that has the old DB-15 Macintosh Video connector, and I was going to see if I can use it as a second monitor alongside my main monitor on the PCI graphics card. The only problem is that it doesn’t seem to display an image? I know the monitor works, and have heard of people using a setup like this, but has anyone else tried it under an unsupported OS and had any success?
Edit: turns out it does work, you just can’t hot plug the old DB-15 monitors
Strange - I don't see why it wouldn't work. Does it work OK if you boot into OS 8 or 9? Shove a boot CD in if you don't have 8 or 9 installed and see what happens.
If you still have trouble in Mac OS 9 I can reproduce your setup if I dig out a monitor (not the same monitor, but I have a G3 and a Rage 128). If it works for me we know something isn't right your side.
ried
Yep, it works indeed. Here's a G3 AIO driving its internal display with its built-in Rage Pro plus two Studio Displays (VGA & DVI) thanks to a Radeon 9200 PCI card.
Nepnep
I did edit it to say that it does work. The way I tried it was hot plugging the monitor into the DB-15 connector which I’m guessing is why it didn’t work the first time. But it works now after rebooting.
Nepnep
No you can't and shouldn't with VGA either, they're not electrically designed for it and you could damage the computer.
Yeah, I learned my lesson. I’ve hot plugged vga monitors in before in other computers but that was mostly due to the connection being loose.
Is that a 6360 growing out of a G4 iMac?
macuserman
You can make an adapter that lets you drive the internal monitor using the PCI graphics card to get a bit of a boost on these machines. I have one laying around here some place in fact.
