"shortly."
meanwhile, one week later..
I think i'm close enough to call it quits now. I have attached the .STLs for the cd-rom drive (815-1690.stl), the eject button (815-1690_eject.stl), and the empty bay bezels (815-1189.stl)
I sliced these using Simplify3d, at .2mm layer height with 1mm automatically generated supports. The supports are definitely needed, and If you're using different slicing software your mileage may vary.
I oriented the parts thusly:
for the cd-rom bezel, I have it sat up right as it would sit normally in real life. It actually consume less material for supports if it's printed upside down, but the finish on the lower lip indentation suffers pretty badly since that will all be built upon support structures.
The empty bay bezel I print upside down, since it doesn't have any fancy features that might be negatively affected by support material.
The cd-rom eject button I printed like this, which is probably not really ideal in the long run since the layer structure is more likely to cause a break somewhere along the body, but printed any other way caused issues with regard to support materials and the diameters of the holes coming out correctly. Depending on how dialed in your printer is, you might want to print this in a different orientation.
And, of course, here are the real-life results:
I'm feeling pretty good on the overall shape/functionality! its not quite 100% but I could keep messing with it forever, so I'm calling it. Gonna move on to the floppy bezel, then do a zip and/or jazz. or if anyone has any specific requests (cause all I needed personally were a bunch of cd rom and blank bezels) I'm up for that!
View attachment 815-1690.stl
View attachment 815-1690_eject.stl
View attachment 815-1189.stl
