TashTalk USB
I am admittedly biased as I adore my Saleae, especially because I can have the analogue view side-by-side with the decoded digital side to track down quirks. But your capture I think is exactly what I needed -
From looking at the Sigrok capture there's pretty significant pulse width distortion on the LC II's packets, and where the ImageWriter should be responding I think the signal is so weak the RS422 transceiver is just clipping it (I see like 30 microseconds sometimes between pulses), so no wonder the PIC isn't outputting anything.
Any chance you have an oscilloscope to confirm, or are up for some surface mount soldering? :) I have an idea on how to fix it, but it does require some 0603 parts being added hah. If not I'll be picking up a really long phone cable tomorrow and can hopefully repro it too.
I don't have an oscilloscope, but I can do SMD soldering. Just let me know what you have in mind. Of course I have no issue just going with a shorter cable too if that is the solution. I have no barbed wire fence in the suburbs!
Ah ok if you are fine with a shorter cable then it is no worries. My current thought is the signal is being attenuated enough that the transceiver is going in to fail safe mode and just going high causing the frames to be lost. I think if we add a little DC bias network on the RX lines to shift the neutral point we can pick up these weaker signals. I am only an amateur hour electrical engineer so i could be totally wrong here of course too.
If I can reproduce this and the bodge makes it better I’ll do a respin of the boards and get one out to you as thanks :)
If you are able to reproduce and are interested in a change to address it, I'd happily test things out. I do enjoy learning more about all of this stuff. Its vintage tech, so I have no expectations that any of this stuff works perfectly at all times.
I'll do another test soon, putting my G3 at the end of the long cord to see how it might "see" the tashtalk serving files.
Well, more somewhat goofy results from today!
I put my G3 at the end of the long phone cord, to see if it would be able to connect to the tashtalk. And, it did not, until I removed the terminator from the phone net connector next to the tashtalk!
I then tried the ImageWriter with the terminator removed. It too was found using nbp-lookup.
That kind of makes sense; the terminator, after all, is essentially a resistor. With the long cable, you've got built-in resistance, so the cable is likely self-terminating :)
@Bolacore do you have a special pap-print you used with your ImageWriter? I took your example and paired it down by getting rid of the postscript stuff but the connection fails.
It does see and connect to the ImageWriter it seems. After a minute or so something times out and the ImageWriter does a form feed. I'll admit, the first time that happened the noise startled me!
I do yes - it’s still a work in progress but as @NJRoadfan mentioned the card is super quirky hah so I had to fix some other stuff. I found the card doesn’t set EOM on ATP responses so we just sat there waiting forever and is why it times out. I tweaked our logic so it’s either “we get EOM or get the expected number of packets” and that seems to make things work.
My codes pretty messy still but I’ll push up what I have so far in a little bit and you can give it a try.
Here's my current WIP stuff that I used to get it all working: https://github.com/FeralFirmware/TailTalk/blob/imagewriter-printing/examples/iw-print/main.rs. It's largely the same as pap-print, but routes the data through ghostscript's ImageWriter driver to convert it to the format needed. It's a hard coded page of course, but you can modify it.
I also added some really basic integration support in the IPP bridge that I used to print Ferris in the other picture, but it's still unstable and not really in a state to be merged. Will be reworking a good bit of this before I add it in later this week.
Great! I'll take a look.
You can send plain text to the ImageWriter (and, probably the LaserWriter) and it will just happily print out whatever it gets. So ghostscript isn't strictly needed.
I'll eventually see about getting the ImageWriter status ported over from netatalk:
On a related note I find it interesting how the IIgs handles printing to an AppleTalk ImageWriter. You pick the printer using GS/OS. Then, any ProDOS application that sends bytes to the printer slot get intercepted and sent out & back via AppleTalk instead. Memory protection?!? No thank you! But hey, it works!
The IIgs printing to a LaserWriter is interesting, too. GS/OS downloads an "Imagewriter Emulator" written in postscript to the printer. It converts ImageWriter commands to postscript.
Do I understand that correctly, that GS/OS sends the LaserWriter a Postscript program which then interprets ImageWriter commands? That’s kindy of kludgy and kind of awesome both at once. Where can I learn more about that?
The file is called IWEM. Its a PostScript program that lives in the System folder. When it prints graphics it uses a font called "Graf font" that is uploaded with the emulator. Each character is a bitmap with certain bits enabled depending on the value sent to print. The downside is that it doesn't print in color (because why would the LaserWriter need that?) and never can properly since ImageWriters blend color by overprinting which PostScript can't support.
On the server side, you can hook a routine to call an ImageWriter emulator vs passing the input as Postscript. The AppleTalk firmware prepends every job with the string "_WBJ_" when the emulator should be activated.
See page 105 (page 117 of the PDF) for more details: http://www.apple-iigs.info/doc/fichiers/AppleShare Programmer s Guide for the Apple II.pdf
Hah I went straight for the hard option - I only used Ghostscript just because the plan was to make it an AirPrint printer too like the others. I forget there was an easy one too :)
Would love to see the PapStatus port added! The current API assumes a Pascal string but should be fairly trivial to expose the binary format instead. What an utterly bizarre system for printing though. I've never had a chance to use a IIgs but now I kinda want to inspect that payload just to chuckle a bit.
On the printer tool front I have it supporting LaserWriters properly now too:
Can rename it, change the default paper size so the printer doesn't complain, set startup page on and off and see the other info they expose. I've not exposed password and zone setting as I have no idea if it would be used, but always can if anyone wants it. I also fixed the tray selection on macOS hosts so that should be in the next release, and also merged in the ATP quirk fix needed for ImageWriters.
