TashTalk USB
Notice that the packet in your screenshot is a NBP Broadcast directed to a router (at least the LC thinks it should be one) at node 129, not a NBP Lookup to the broadcast address. In this case, the router at node 129 should be re-transmitting those packets at NBP Lookups to the broadcast address.
Without knowing @iigs123 's network configuration, its hard to know what is going on here.
Plus there are multiple problems. This example appears to be a non-responsive router. while the issue in the other two packet captures with TailTalk is that it isn't handling being on a routed network correctly, which causes problems with NBP lookups.
On non-extended networks, TailTalk needs to listen to RTMP broadcast traffic to glean the network number and node number of the router, then issue a ZIP query to the router to get the zone name.
On extended networks, TailTalk needs to broadcast a ZipGetNetInfo request, get the correct network range, node number of the router, and default zone, issue a new AARP Probe inside that network range, followed by a ZIP query to the router to retrieve the rest of the zone list.
I replicated the capture - the network is ImageWriter -> LC II -> TashTalk alone on phonenet.
I tested the new "Emulate a LaserWriter printer" option. Works, I don't know why I think this is so fun 🤓 I've never had printer on a classic Mac so perhaps it's just it. Thanks for adding this!
On my System 8 machine, which I happened to have at hand, I used the built-in Laserwriter 8 driver. Not knowing any better, I picked 'Color Laserwriter 12/600' and 'Generic' as the PPD File, seems to work just fine.
On my modern Mac I used 'brew install ghostscript' as instructed and it installed ok (and I can run 'gs') but TailTalk still doesn't allow me to select the 'Convert to PDF' option: it says it Ghostscript still isn't found. I tried rebooting, but still no, do I need to do something else to enable it?
Here are some prints from my OS8 machine (converted to PDF from the PS files on my modern Mac) in the meanwhile:
Something to consider for a future version: I would love an option to keep the host Mac awake while TailTalk is running. I'm always forgetting about it, it falls asleep, and the share gets lost.
Missed this earlier sorry! That _should_ be the only thing you need to do - TailTalk just tries to run "gs --version" at start up and if that succeeds it considers it present. If you do "gs --version" in a shell, what does it return?
Ooo I'll have a look at how to do this in macOS, that would be a handy option I agree.
Nice! It could be as straightforward as a toggle "Keep Mac Awake" (indefinitely) but v2.0 might have some preference of an upper threshold of time. That way one could override the system's temporary short duration (mine is 2 minute sleep on battery) for say, an hour, and not keep it on forever.
My ImageWriter showed up today, and I have a LocalTalk board from @defor arriving soon. Hopefully I can replicate this and we can get it working - thanks again for your patience :)
It looks like it's pretty trivial to do a simple "Keep Awake" button. For the first true 1.0 version I want to make a little config menu as I think the main window will start getting pretty big with all the things.
