There's a good chance the expansion chassis likely rewrote address access to PDS cards since the SE and Portable address spaces aren't quite the same. It's hard to say for sure because I've never seen one outside of a picture I have in a magazine.SE PDS cards run in an expansion chassis for the Portable, whose PDS is ostensibly the same as the SE PDS. I'm not lookin' as I'm a bit burned out with other projects ATM. If one of you guys want to take a look at the Luggable/SE PDS address ranges, finding them identical could be a big step forward I'd think?
There are some "free" address spaces that overlap between the Portable and SE, but those are in the Portable's upper RAM space, so if you use those you could end up limiting the Portable to 5-6MB of RAM rather than the full 9MB, unless you give the accelerator additional RAM. There are some Portable PDS cards around that do this since having that much RAM was uncommon at the time.
