Picked up another iifx
So if course has some battery damage. So couple of questions…
Does it look like it can be repaired or should i look into a reload board? The rtc chip is done. I have spares. But another chip is toast and some legs are missing from another.
Another question is how can one tell the memory size? I was hoping to uograde my working iifx to more than 8 megs.
  • IMG_1398.mov
    IMG_1398.mov
    95.2 MB
These RAM simms looks like 1Mb simms to me. 1Mb simms are not very rare. But simms with more Mb's are very rare.
Edit: I see in the video the the reset button is missing. Is a model used on various logic boards, so should be find easy.
Yeah i figured it was 1mb simms. It also has a 4 bit macintosh ii card for 16 colors.. wow thats a lot of colors lol.. not.. at least the video card works. Will check ram next
So pulled the two bad chips and cleaned them. I will either need replacing or dremal into the top. Lots of broken or missing traces.. so still uncertain if i should reload this one?
