Hello everyone,
My Power Mac Performa 6200 is showing dark vertical lines. I already tested it with another LCD monitor/cable and the problem remains.
I did a full recap of all the aluminum electrolytic capacitors on the logic board and also on the power supply. I found some bad capacitors, but none were completely failed. I only saw signs of capacitor leakage in the power supply, on the 2200uF capacitors, but it was easy to clean and it seems to be working fine. Even so, the video problem stayed exactly the same.
Apart from the video, the system works perfectly (it boots normally, chimes, and runs the system without issues).
I noticed that an integrated circuit near the video connector (on the separate board on top) is getting quite hot. I'm not sure if this is normal operating temperature for it.
My questions are:
Any help or suggestions are welcome. I can take more photos if needed.
Thank you!
![IMG_20260618_214638815_HDR[1].jpg IMG_20260618_214638815_HDR[1].jpg](https://68kmla.org/bb/data/attachments/100/100398-9adf451ad530480f4f640b6db9398c47.jpg?hash=Swx03VHCJ3)
![IMG_20260618_220710954_HDR[1].jpg IMG_20260618_220710954_HDR[1].jpg](https://68kmla.org/bb/data/attachments/100/100397-558393c1817d7f250df746e143e70310.jpg?hash=sMfIv_0iVO)
![IMG_20260618_220304846_HDR[2].jpg IMG_20260618_220304846_HDR[2].jpg](https://68kmla.org/bb/data/attachments/100/100394-ee8f37db429eb0b5e578b52fc4b45957.jpg?hash=8tDz793pm0)
My questions are:
- Is it worth checking the tantalum capacitors on the logic board and on the separate video board?
- Or should I look for something else (maybe related to the video chip or VRAM)?
Thank you!
