Having a done a number of tally mods, my response to that would be is it worth it, I think so, they are really fun machines when you shove a stupid amount of stuff into a small case like that. Kind of like what happens with SE/3- maxing. At the end of the day, though, what you get is not going to ever be any better than a 6500 at best in terms of performance or capability, in fact because of the screen resolution, you might even argue that it’s less useful.
I’m actually planning to take all of my systems and rebuild one when I have a moment into what I would consider the best option out there, and in the process I fully intend to add the video output port just so that if I get to the point where I can no longer really read the screen or whatever, I at least can connect to a nice large external display.
From experience, the most problematic part of working on these mods has always been notching the chassis. That’s sad, even if you do this, if you happen to have a donor harness around, that is separate from the original, you should be able to return the system back to stock no matter what.
In the modern day, I would say that there were two more pain points that I’ve run into personally.
- accidentally breaking the harness ribbon clips when building the harness
- accidentally breaking the analog board connector when reassembling it.
In both cases, if you do end up, breaking them, and obviously epoxy the parts together, should be careful so you don’t have to, but it still might be a bit of a gamble regarding those ribbon clips.
I think the question probably is most important to ask from a collectors market perspective.
- Firstly, do you even care about that. If you do, do you believe that the value of a nicely modded system will go up proportionate to a stock machine.
- Secondly, I feel like some of these questions are coming about due to the short availability of 575 boards which used to be the more desired to upgrade, at least in our circles because of the less impactful modifications needed. I personally find that high in 6500 boards are becoming harder to find in the last few years. I suspect the same 550/575 scarcity issue will eventually bring about the same situation.
At the end of the day, it’s your machine, do what you want with it.
