Guess the NuBus card
Use tattletech to see what it reports as. There isn't much to go on. The big chip is an FPGA or a CPLD, so there isn't really any branding visible other than the ROM name, which isn't something obvious.
Well it does not work with apple 13” monitor. Anyway If any interested in this card I can sell it, I do not need it as I have supermac ones…
Yeah, it is probably fixed timings for a specific 19" monitor. You might have better luck with a late model multisync CRT or very flexible LCD (some ViewSonics and HPs will work with just about any signal).
Does it show the monitor resolution in TattleTech or Monitors?
Also, as said @finkmac you should dump the ROM to extend this collection and enhance these tools:
well then I need a guide for dummies as I am not familiar with extracting ROMs :(
