Use tattletech to see what it reports as. There isn't much to go on. The big chip is an FPGA or a CPLD, so there isn't really any branding visible other than the ROM name, which isn't something obvious.
Yeah, it is probably fixed timings for a specific 19" monitor. You might have better luck with a late model multisync CRT or very flexible LCD (some ViewSonics and HPs will work with just about any signal).
Does it show the monitor resolution in TattleTech or Monitors?
