Portable LCD dims, but evenly all over
alexGS
I haven’t seen this before - a non-backlit Portable where the whole display dims perfectly evenly to black in about 5-10 minutes, then recovers from black to normal when powered off for about the same length of time.
In that respect (the recovery), it seems the same as Tunnel Vision, except without the circular effect, blotchy corners, or any inversion or burn-in going on. I have seen Tunnel Vision on another Portable and on numerous 170/180 and there’s usually a ‘speckled’ effect where the pixels darken - this doesn’t have that. All the pixels darken smoothly by the same amount.
I thought I had found the cause when I discovered the contrast control in the Portable control panel had no effect during the initial five minutes of correct display, but then I tried the LCD on another Portable and had the same darkening even after the contrast control worked normally.
And conversely, the good LCD from the other Portable works fine on this Portable (despite the contrast not being adjustable - so that’s obviously a separate problem on the logic board, probably a broken trace between PMGR chip and a transistor).
I tried replacing the two electrolytic caps on the back of the affected display panel; no change. Next, I’ll replace the tantalums as well (I note they have silkscreen markings indicating space reserved for radial electrolytic caps being mounted instead of the tantalums). There are also three variable resistors, I tried tweaking those but couldn’t observe any change (wonder what they do - timing of the data?) I hoped perhaps they might adjust out a DC offset that I guess is causing the darkening. I’m suspecting perhaps a partial short in a tantalum is pulling something to ground slowly.
In an ideal, logical world, the fault in the display panel’s drive circuit will have directly caused the failure of the contrast control adjustment, e.g. a shorted tantalum has overloaded the contrast-signal drive transistor, but of course we know that 35-year-old hardware doesn’t have to obey logic :) multiple failures from separate causes are perfectly possible.
I don’t want to separate the good LCD from its PCB so as to swap with this other display, for fear of introducing Zebra Strip problems that neither display has at present. But I suppose that would be the only way to really prove that the LCD isn’t faulty, and that the problem is in the drive circuits.
I just wondered if anyone had seen this before, I spent several hours searching (and of course, re-reading through many Tunnel Vision threads with baking etc.), and so thought I’d post to start something for the next person to find in a few years ;)
Any other updates on this problem? Mine is acting the same.... Glad there is video out...
I think it was a variant of tunnel vision where the ‘tunnelling’ had progressed all the way to the centre. Tunnel vision usually affects the edges, but I guess the moisture ingress (or whatever it is) eventually reaches the middle of the display, so that the entire display goes dark and not just the parts around the edges
No solutions then…? Until a replacement LCD option.
You can try baking the display - some people have good success. Kitchen ovens are dangerous as they cycle on and off, run wildly over temperature and can damage the display (black circles, or small dots that turn into black circles as the display is used, similar to the tunnel effect around the outside).
I think a better method is to sit the display on the heat bed of a 3D printer. I got the feeling that it was making an improvement after about 12 hours of treatment, but it was the outside edges that were most improved, probably because the metal frame sitting on the heat bed conducted the heat into only the outside edges of the LCD.
Therefore I ended up with ‘reverse tunnel’ effect where the centre was darker than the outside edges. I wonder if cardboard or a silicone pad trimmed to sit under the display may help spread the heat better. I also wonder whether including desiccants in the 3D printer’s enclosure may help.
A replacement LCD seems very unlikely for an active matrix 640x400, reflective type with a whole lot of control logic on the circuit board behind it. Powerbook 170/180 has a similar display usually with the same tunnel vision, but as I recall, the circuit board is different
