Help with srecord for splitting and joining ROMs
I'd like to get the hang of joining and splitting Macintosh ROMs and have been recommended srecord by the forum regulars, but I'm having some trouble with interleaving.
I have installed srecord 1.65 on my Mac via Homebrew.
As an experiment I'm trying to combine the High and Low ROMs that I dumped from my PowerBook 1400 (I had the chips out, and used a T48 to read them).
Here's the first four longwords of the Low ROM:
50192A00 FA4EFA4E F3320000 1600FA4E
Here's the first four longwords of the High ROM:
A2830000 7D076800 64000000 4E00D04E
And here's the expected code when the ROMS are correctly combined
83A21950 0000002A 077D4EFA 00684EFA 006432F3 00000000 004E0016 4ED04EFA
The command I'm using in srecord is
srec_cat -o 341S0203-4_srec.bin -binary 341S0203-Low.bin -binary -unsplit 2 0 341S0204-High.bin -binary -unsplit 2 1
But the output is
50A21983 2A000000 FA7D4E07 FA684E00 F3643200 00000000 164E0000 FAD04E4E
I tried going the other way, i.e. taking the combined ROM and trying to split it with the following command:
srec_cat 1996-10_83A21950_PowerBook_1400_1400cs.bin -binary -split 2 0 -o Low_srec.bin -binary
srec_cat 1996-10_83A21950_PowerBook_1400_1400cs.bin -binary -split 2 1 -o High_srec.bin -binary
I get the following:
Low:
83190000 074E004E 00320000 00004E4E
High:
A250002A 7DFA68FA 64F30000 4E16D0FA
I'm at a bit of a loss here, so any help would be appreciated. I'm basically using the same commands as everyone else is using so not sure where I've gone wrong.
Attached are the high and low rom dumps as well as the correctly combined ROM (as found on Macintosh Repository and Macintosh Garden).
The Low and High ROMs take two bytes at a time, so I guess the correct -split arguments is going to be -split 4 0 2 for High and -split 4 2 2 for Low.
But the two bytes are swapped, so the first thing to do is a -byte-swap 2 before the split.
I don't have srecord on my Mac to test this. I would just ask google how to write a perl script to do the job...
Thank you – this has indeed worked great.
The exact commands I used are:
To Split
srec_cat 1996-10_83A21950_PowerBook_1400_1400cs.bin -binary -byte-swap 2 -split 4 0 2 -o High_srec.bin -binary
srec_cat 1996-10_83A21950_PowerBook_1400_1400cs.bin -binary -byte-swap 2 -split 4 2 2 -o Low_srec.bin -binary
To Unsplit
srec_cat 341S0204-High.bin -binary -byte-swap 2 -unsplit 4 0 2 341S0203-Low.bin -binary -byte-swap 2 -unsplit 4 2 2 -o 341S0203-4_srec.bin -binary
What I remain confused about is whether these are the arguments that are going to be needed for joining/splitting all Old World Macintosh ROMs, or if it somehow varies between model. @Bolle and @demik seem to be happily using srec_cat without these extra arguments, and Kai Koba's instructions over on TD also omit them for example. I notice that people are tending to use srecord on Windows (in command prompt) so I wonder if that is relevant also.
