I've got an empty PowerBook Duo in need of a complete rebuild with current LCD. CM4 setup won't fit, that one's going into my original, bought new PowerBook 100.
I’m no emulation expert either, but you can generally set the resolution and color depth to the maximum supported by the OS you’re running. The main trade-off is that higher resolutions and deeper color palettes (like 'Millions of Colors') will significantly impact performance.Wow! Fabulous reference linkage, thanks. Looks like I'll probably set up well enough to do OS9 in sheepshaver on the CM4/Pi4 platform at some point? Apparently it had not yet become compatible with Pi4 four years ago. I wonder if that's been achieved?
Wondering about the limits of emulation on the Zero 2 W. Didn't get a a Pi platform comparative benchmarking hit, but in his video, it looks like jaromac had SheepShaver running OS9 on a Zero!
Looks like I'll be ordering up that Zero 2 W with external antenna mod after all!
Absolute noob on the emulation front here: can high resolution VidCard output be done in emulators in their present state or am I stuck running a standard 3:4 resolution letterboxed on my PowerBook 100's wider LCD? 640x400 is a possibility, but a drag even so.
Thanks, I hope somebody else will implement a DOA PowerBook reincarnation with it. Great price I think?^ Nice find, that display looks great for a color PowerBook project.
Is your goal to output 640x400, or to fill the panel?Don't remember the panel's specs, but it's a wider aspect ratio than the PowerBook 100's 8:5 640x400 resolution, so it's sounding like a pillared emulation/full screen Linux setup for that one.
Most emulators have their own scaling feature to fill the screen without changing the resolution of the screen but I suppose it would be faster if the panel controller had its own scaler.I'm hoping that panel's controller will be smart enough to autoscale 640x400 to 1280x800?
I don't know. I think most emulators compile for Linux but I've never tried any Pi myself and I don't recall which emulators have been tested on Pi.Need to look at DingusPPP, it looks fabulous, great work! Will it run on Pi Zero/Pi4/Pi5? Didn't look like SheepShaver did or does it support them by now?
So when my MDD/FW400 OS9 Special Edition gives up the ghost with no G4 PortlyTower as my habitual backup/upgrade path . . .We're so far past the original hardware I don't think speed will be an issue on just about any modern computer hardware.
. . . I can drop whatever Pi Compute Module I/O Expansion Board combo is compatible with emulation in there and . . .![]()
