Apple LocalTalk interface box
Good news, works fine between the new LC475 and the Performa 5300.
Now I have working system to measure on with the logic analyzer.
My first ideas :
- it's slow to todays standards, but for the 90 with only small files and minimal extra HW needed I would have loved it.
- Also the slave computer gets slower, even on the LC475.
My original plan was to use the external clock option (or patch the mainboard clock to the 85C30) to increate the speed x3 or x4,
but this will probably only increase the load on the CPU, making the system even slower ?
AppleTalk was cheap, but without any ram buffer nor DMA support, it needs the CPU to often to intervene.
Just within the past day or two, I came across an extension or some software that allowed DMA transfers for AppleTalk. But now after reading your post, I don't remember where it was I found it.
My first ideas :
External clock is probably the easiest and best choice:
https://68kmla.org/bb/threads/localtalk-but-faster.45615/post-505309
The PCLK could be used, but there's a couple issues with that:
- Different Macs have different PCLKs. Maybe only Power Macs had PCLKs in the >10MHz range.
- The PCLK has to go through the baud rate generator which reduces the maximum bit rate by a lot. You would need > 4 * 3.678 MHz to exceed the 230.4 kbps option allowed by using the 3.678 MHz from the RTxC pin.
The external clock can easily do 1 Mbps because both machines will use the same clock and therefore can use the X1 Clock Mode instead of X16 or X32.
It might be interesting to see if you can output the transmit clock TRxC to one of the pins (HSKi?). Then one Mac can be the source of the external clock and they can use X1 mode. It would require special cables.
I know the AM85C80 SCC+SCSI chip also supports DMA for the SCC (and the SCSI), but this signal runs only to the GLUE logic VYI6508-2 gate array. Is there any documentation available about this chip how to program it please ?
Thanks for the link, I was wondering how to set the external clock option and found something in that thread.
It's input only (differential buffer in-between), the signal also need a boost to be used by multiple other Macs.
I would go for 1 external 1MHz clock and a good driver chip, it doesn't even have to be a xtal oscillator, a simply clock generator chip will also work and the frequency can be changed on the fly for max speed or reliability.
Reading the "Guide_to_Macintosh_Family_Hardware_2nd_Edition_1990" I found some interesting info :
1. The /W/REQA signal from the SCC (only option for DMA) on the Plus, SE and SE/30 goes to PA7 of the VIA chip,
So DMA is not possible on the old Macs. Only on the IIfx they go to the IOP.
This PA7 pin is used the check for incoming data during disk access, as interrupts are disabled by it.
Loss of data by AppleTalk during disk access is possible, increasing clock speed will not help.
2. Synchronous communication is only supported from SE and up, not on the Plus.
3. AppleTalk is a synchronous protocol, but the AppleTalk Driver operates the SCC in asynchronous mode ???? Need to check this.
4. The max speed is 500Kbaud on Plus and SE models in synchronous mode, on Mac II this is 900Kbaud.
In conclusion : Max speed increase is 3x, or only 2x if I also want to support Plus and SE models.
My LC475 is already slower at normal speed, so on a SE or Classic it will probably be worse.
Asynchronous in this case just means that the sender and receiver don't share a clock? They must use the x16 or x32 or x64 clock mode to recover the clock from the receiver. They don't have a start bit or stop bits? They use a SYNC character?
I'm adding logging to DingusPPC to show how the SCC registers are modified for AppleTalk (used in Mac OS) vs normal asynchronous transmission (used in Open Firmware or terminal app in Mac OS).
I used a 555 timer with potentiometer to get 1 Mbps for a Mac serial port to Sony PlayStation controller/memory card/Multitap adapter.
I'm back and first thing I did was the repair a not working SE/40 with success :) Clear picture, no strange noises from HD nor fan.
New from September 1996 and last used on November 1998, just run as they say.
This will be a perfect candidate for the Low End MAC on the Apple Talk network.
Looking at a beige G3 266 now as Top line machine, I read this was the last Mac with Apple talk ?
Meanwhile I'm experimenting with my home made AppleTalk hub and KVM.
Found an alternative to the interface boxes and cabling, as these parts are not to be found in my country.
Solder a couple of PS2 female connector in parallel, only 4 pins to solder on every connector.
For cabling I used also PS2 cable (SVIDEO could also work) and broke away to plastic key so they will fit to the MAC.
Works perfectly on 4 MACs, as a test I used 20m cable for one machine (others are 5m), no difference in signal.
Had a look at the signal with the scoop, all withing spec...
Don't know if there is a tool who will show any errors, signal noise ratio ?
I would like to test it with a higher external clock, yes this signal is also available on the PS2 cable.
But for this you need to switch the receiver first to external clock input, don't know if that is possible with the normal control panel ?
Does the B&W G3 than also support synchronous communication, what I found on the web is that the Griffin gPort only converts to RS422 signals ?
I think it does all the things the Z8530 SCC can. Same register set for all 68K and PowerPC Macs which include an SCC.
I'm not sure what you mean by RS422 signals. RS422 has differential pairs while RS232 has a single line each for transmit and receive. RS422 has a certain voltage range that might be different than RS232. Even with the differences, an adapter can work between RS422 and RS232.
What exactly do you mean by "synchronous", here? The term refers to communication where both ends are working from the same clock signal. In traditional serial signalling, this is achieved by continuously sending ASCII SYN ("synchronous idle") characters when nothing else is being sent, so that once the receiver has figured out the timing it doesn't have to worry about losing it again. None of that applies to LocalTalk's modified HDLC format, which as far as I'm aware is always asynchronous (the clock timing of every newly received message is independent of any others received previously).
