Apple LocalTalk interface box
Trianon
Hi all,
Can you connect 2 macs on an AppleTalk network with only a serial cable (as for a printer) or do you always need to the interface boxes ?
I searched the internet and it suggest it would be possible, but not working for me. I do think it should not work from what I read in the specs.
It's really difficult to find those boxes in Belgium (up to now I found only 1 as part of the big package of cables only as pick-up).
Has anybody any experience in building an alternative ?
Br,
Steve
Yup :) I don't even remember where my boxes are as I rarely need to connect more than two macs.
Just use a serial cable, nothing else required. Good luck!
Thanks for the confirmation,
I will have a good look at youtube how it's done as I know the HW is good (works with ZTerminal).
Up to know I was not able to see the other computer in the list of AppleTalk control panel.
Br,
Steve
My main goal is to write a "sceen-saver" program the runs on multiple Macs in parallel,
showing a Amiga ball (or whatever) bouncing over all the screens.
AppleTalk could be a solution to communicate to each mac where the ball will go next.
It will be software setup. Look for something like "setting up appleshare".
Yeah, there is an API for applications to communicate over the network. It's not the worst. Even HyperCard supports it - I wrote a mandatory network chat program as a kid 😆
You do need to specifically turn it on though. There are two switches, one for applications to talk, and one for file sharing.
printer cables are cross over but modem cables are not cross over. Well, a modem cable probably won't be mini-din at both ends so it doesn't matter.
realistically you probably won't find a non-crossed over din8 serial cable. i beeped out every single one of mine and found zero straight through ones.
no, no... I needed one.. for my sun workstation keyboard! I had to buy one 😡
I have both, and found this out the hard way that both are not the same.
I got one Apple (cross) cable when buying the 6300 so I made a serial connection with Zterm between 2 machines, worked file.
Took an USB to RS232 adaptor for my Windows laptop and swapped out the RS232 for RS422 driver, used my SUN cable now and worked fine.
But then a couple of days later not any more ... yes I swapped both cables !
As I understand AppleTalk (or normal serial communication) only used the 2 top left and right pins for differential signaling, so
a cheap 4 pin SVIDEO or 6 pins PS2 cable can also work if you cross the wires ? Those I can still find at a bargain price.
Instead of cutting up the wires to cross them, I plan to build a small 8 port HUB with PS2 connectors were I cross them instead.
Maybe also try if the HUB can supply a higher clock to all the Macs, oscillator + driver chip. Speed x3 x4 ...
I found many papers on AppleTalk, mostly about the API, but does it use the default asynchrony communication protocols or HDLC ?
Br,
Steve
LocalTalk uses a variant of HDLC, not standard teletype-style serial characters.
And yes, there are some straight-through mini-DIN-8 cables out there which look just like the normal crossover kind, and will make a direct LocalTalk connection inexplicably not work. If they are Apple-made cables, you can tell them apart by the tiny part number moulded into the undersides of the plugs, but I certainly don't remember what part number has which characteristics.
The straight-through kind of cable is vital if you have a naïvely implemented serial switchbox. (The kind meant to let you choose among several printers/modems etc)
I own such a switchbox manufactured by people who did not have a full understanding of the problem. Its ports are wired straight through, meaning that if you plug in a normal (crossover) cable to the host machine and normal (crossover) cables to the peripherals, it will cross over twice and act like a straight-through cable. The only way to make it actually work is to switch to using a straight-through cable to the host machine (or else a bunch of straight-through cables to the peripherals, but that would be sillly in most cases.)
I was able to connect my LC III to my Power Macintosh 7200 with a din printer cable using the printer port. However, I decided to change to PhoneNet, because phone lines are easier to find (in case I ever want to make a larger AppleTalk network).
I found a video of "Adrian Basement" on Youtube where he also has the same issue is I have, but with the full PhoneNet network setup.
He connected 2 Macs, made the correct setup but did not see the other computer in the panel as I do.
He then makes a jump in the video where it works and says he had some missing files on the computers...
So it's probably just a missing file or driver issue, I do have some original Network Install Disk, lets try to install it.
Br,
Steve
Thanks for the doc.
Some 30 years ago my jobs was to created CPU boards with the Motorola 68360, it's a 32 bit communication processor with 4 SCC onboard that support AppleTalk. I kept the original ceramic parts used for the development up to now, because I always wanted to build 'something' with it as a hobby. So now I do know what that something will look like : An AppleTalk switch !
Like they said in the A-team (for the readers of my age group), "I love it when a plan comes together"
LocalTalk defaults to the printer port, so make sure both ends go into the printer port on both Macs. There shouldn't be a need for anything else software related because LocalTalk works right out of the box.
Check to make sure none of the pins aren't bent inside the din. If you do have an Ethernet card installed and AppleTalk has been using it then you'll need to go to the Network or AppleTalk (Open Transport) Control Panel and switch the AppleTalk connection from EtherTalk to LocalTalk.
In classic Mac networking usually the icon for LocalTalk inside the Network control panel is a Printer. There is a way to use the modem port instead but it requires an additional driver. The icon for the Modem port inside the Network control panel is a telephone but it won't be there by default, you'll need the additional driver to use the modem port.
Good news, works fine between the new LC475 and the Performa 5300.
Now I have working system to measure on with the logic analyzer.
My first ideas :
- it's slow to todays standards, but for the 90 with only small files and minimal extra HW needed I would have loved it.
- Also the slave computer gets slower, even on the LC475.
My original plan was to use the external clock option (or patch the mainboard clock to the 85C30) to increate the speed x3 or x4,
but this will probably only increase the load on the CPU, making the system even slower ?
AppleTalk was cheap, but without any ram buffer nor DMA support, it needs the CPU to often to intervene.
