Question about the Macintosh Portable
Hello everyone I am hopefully getting my first mac as of this Thursday; (If the Thrift store still has it) and was doing a bunch of research on it before I got it.
I watch This Does Not Compute and I learned a lot about Older macs. I especially liked his Mac From New Parts. At the thrift store I work at a Macintosh Portable showed up last week from 1989. So I decided to try to figure out what was needed before buying. While looking I found out that the screens breaking is very common so I though about it; and came up with a idea. (It might be really dum)
I found this post about a rasberry pi mac portable and he used a ipad 2 lcd. And then I found this adapter made by Androda and wondered... Buying a vga adapter for the ipad 2 lcd to the adapter and then plugging it into the adapter that androda made would that work? Would you even be able to make it thinner and put it in the screen bezel? hooking it all up with wires?
Again its just an idea that is probably horrible but it is a thought considering that all of the matrix screens are really old now.
Thanks
-Froggy
Anything is possible if you throw enough code and electronics at it.
Using the Macintosh Portable video output was discussed at:
https://68kmla.org/bb/threads/macintosh-portable-video-adapter.32038/
Here's an Apple Macintosh Portable Video Adapter M0251 description:
https://fsck.technology/documentati...ays/macintosh-portable-video-adapter-8909.pdf
Did Apple ever produce this?
I didn't find much about replacing the display itself.
The Macintosh Portable video output seems really simple:
https://allpinouts.org/pinouts/connectors/computer_video/apple-macintosh-portable-video/
iPad 2 LCD is 1024x768. Would you upscale 640x400/480 or would you just use the middle of the display? Maybe there are more appropriate LCDs with better matching resolutions or sizes. I would prefer not converting to analog VGA if possible. Find a DVI/HDMI solution?
Here's a discussion of the display hinge cracking on the Mac Portable:
https://tinkerdifferent.com/threads/cracked-hinge-on-mac-portable.4835/
Here's a discussion about compatible battery chargers:
https://tinkerdifferent.com/threads/powerbook-power-adapter-compatibility.736/
There's threads about replacing the battery. Search for "Battery Eliminator".
This post mentions using a LiFePO4 battery instead of the Sealed Lead Acid battery.
https://mastodon.social/@paulrickards/111762914299639568
I don't think the screen is a major area of concern, at least not compared with problems around the power adaptor, lead-acid battery, motherboard capacitors, and hybrid module. I'd focus on whether the right power adaptor is included, to start with.
Yes it does come with the original power adapter and I think it comes with original every other part.
It even looks like it comes with a ram upgrade (not certain because I dont have a picture its all in my memory.)
I was just asking the question about the lcd, not because I wanted to make it or anything or that I was worried about it but just because I was wondering if ever it was needed it would be a good idea at all. I really am not concerned about lines, it was just that so many are being parted out (or so it seems) that I wanted to ask the question.
@pl212 do you have a list of all the caps I would need? Are there any caps anywhere but the logic board that I should replace?
Do you know what battery I should use? Would any generic sla battery at 6v any amp hour work?
What is the hybrid module? Is that the charging module?
What would be the best replacement scsi to put in? A blue one or a zulu or what?
What is a good price for a very yellowed, broken hard drive, dead battery, macintosh portable price? $150? $200?
Thanks - I started this sub forum to ask questions!
- Froggy
It's totally possible. Although as you can see in those pictures the 9.7" iPad display is a bit too small for the bezel, so you lose a good bit of the display area. With a larger display, you can fill more of the bezel at least:
Also can I use any amp hour battery or does it have to be 5ah? Could I put in more amp hours?
The capacity of the battery doesn't matter that much, just as long as it's compatible with the existing charging circuitry and can supply enough current. "6V" sealed lead acid or LiFePO4 batteries should work fine, while NiCad, NiMH, and Li-ion batteries would be a bad idea to use without additional circuitry.
Does anyone have an actually list of the caps with pictures of where the caps go on the logic board?
This is going to be my first big soldering project, (besides putting hall effect joysticks on xbox 360 controllers)
And I really want to be prepared for what might be to come.
Thanks
-Froggy
Thank you, I didn't think about that. I will take a piece of trash electronics from the thrift store and practice on that before working on the Macintosh Portable.
Also thanks for the list. @Juror22
Does anyone know what the best scsi is to put in the portable? I read that someone put a blue scsi but it was doing something weird and he put in a scsi2sd or something to that nature.
This is the parts list I have right now. Anything I should add?
SCSI ADAPTER
BLUESCSI
Flux And Wick
An SLA battery that will fit in the compartment or a Battery Elimintator
The Capacitors
And 99% iso alcohol
Thanks
-Froggy
i'll be real man. you're getting way ahead of yourself.
practice your recapping skills first, then start shopping.
also, don't buy that flux/wick bundle... that's not where you want to save money. stick to brand name, like mg chemicals or kester
something like this is fine for a battery
No need to try to put them down. You learn by doing the work. OP has clearly done/is doing their research and I'm confident they'll get it running.
A couple tips:
- As others have said, definitely practice removing and replacing caps on a junk board before attempting anything on the Portable. Everyone disagrees on what the correct way to remove surface mount capacitors is. The real answer is that there is no correct way and that you should just use what works for you. Branchus Creations' soldering guides are a great resource on all of this:
- Do not attempt a power-on until the motherboard and AC adapter have been fully recapped, and until a working battery has been installed.
- I have cap reference for the Portable on my website:
Non Backlit: https://macdat.net/repair/cap_reference/apple/powerbook/portablem5120.html
Backlit: https://macdat.net/repair/cap_reference/apple/powerbook/portablem5126.html
You need a proper 7.5V 1.5A current limited AC adapter. The Portable does not care for the usual guidance that using a higher current supply is safe. The original adapter will work best, but it will need recapping like the computer does. I have reference for this on my website too: https://macdat.net/repair/cap_reference/apple/powerbook/portable_ac.html
I have written information on why the Portable is so picky about power management and batteries on my website as well. This info was vetted by resident Portable expert @techknight and gives a good overview about what to be careful with: https://www.macdat.net/macintosh/powerbook/macintosh_portable.html
Thank you for the constructive critisisum. I bought it...
The lead acid battery leaked and ruined the battery compartment. Thankfully it looks like the damage is minimal, maybe a replaced adb connector anIMG_20260328_181025.jpgd headphone jack, or "shudder" traces!IMG_20260328_181027.jpg
I cleaned the board and it looks like there are just some leaky caps, and the damage on the front of the connectors.
Thank you for the support my 14 year old self is lucky to have all of you to help me. I got a ram expansion and I just hope I dont have to bodge, thanks!
- Froggy
Ports look fine to me. Got a photo of the top side of the motherboard? I can give an analysis on the damage.
I don't know for sure if the floppy drive on the Portable needs recapping or not. Maybe someone else can chime in.
The Chips circled look like they have damage, and so do the other circled things.
the ports have corrosion inside of them that is really hard to see but the pins are fully corroded, Thanks for all the help and if you know where to find the ports it would be greatly appreciated.
I have been practicing my soldering skills on a dvd player too.
Can you clean out the plugs? Thanks, Froggy
Chips look dirty from cap leakage. I don't see anything in your photos that looks like damage which would require component replacement (aside from the capacitors). I wouldn't bother with replacing or messing with the ports until you have the logic board running. Then, you can deoxit and clean the connectors and see if any are actually not working.
where's the putdown? please highlight it.
i don't think it's bad advice to suggest not running around and buying every bit of hardware possible. start small and simple
Thanks, I ordered all the caps off mouser... they might not arrive until 2 months from now just because some are on backorder and i didn't want to pay twice for shipping. I also got the battery eliminator so I can test the board.
@finkmac
For me there was no put down but I definitely am glad you want me to have practice before doing the caps.
