Need Resistor Value from PowerMac 7600 Power Supply Delta DPS-150GB
powellb
Rather the pinging an old thread about this power supply, I am asking broadly.
All, I am refurbishing the power supply on my PowerMac 7600. When replacing C2, I had to remove all of the white adhesive around it, and it turned out there was a resistor in there that was pulled from its leads: R41.
Does anyone have a Delta DPS-150GB open that could look (or test) what the resistance value is of R41? I haven't been able to find any schematics of it.
Thanks!
Thanks to you, I know how filthy and dusty my 7600 power supply was inside...yuck! 🤢
I did not remove R41 from the glue, but I desoldered it and bent its leads away from the edges of the holes so I could measure it out of circuit. I got 838.6 kohms, which is right near the bottom of the range for the E96 (1%) value of 845k, so I bet that's what it is.
Thank you very much, this is a great help! I was tracing through the diagram to try to figure out what is was doing. The output of bridge rectifier goes into positive side of capacitor C1, but that also goes through R41 that then goes to R42, where I lose what is happening.
I really appreciate it, and I hope that your PS is now cleaned up!
Just to follow up: I ordered metal-film E96 845k resistors and put the PS back together. Everything is working perfectly. Nice to have that PS rebuilt. Thanks again for checking for me!
I'm glad to hear that! Was this a preventative recap or a repair? Aside from the dust, mine looks pretty good inside, and the caps are good brands, so I'm inclined to leave it alone since it's working fine.
With R42 being 700k and in series with R41, perhaps they form a (very low current) voltage divider for some purpose.
I was replacing caps in a monitor and other things so I figured I would do the 7600 psu while I was doing everything. It was working before, but I wanted to refurbish it and check joints. All redone and should be good for the rest of my life!
im not a psu person, but the output from the bridge rectifier goes to those two caps to double the voltage (I think) for 110v supply. That resistor line actually goes from the rectifier off to something else…
Hi there, new to this forum but I am starting the process of recapping my Power Mac 7500 PSU, which should be the same one as the 7600, the 614-0039...mine is an ASTEC. I have the PSU open and yea wow, it's super dusty. I have a couple cans of air I'm gonna blow out the dust. I also have a Console 5 recapping kit for the PSU. Question is, did you desolder the leads from the plugs to get that PSU pc board out...or did you do something else? Just wondering what the best process is for getting access to the board to replace the caps. If there are online guides for doing this that anyone knows about please feel free to point me at them, I've found some pages but nothing like a real guide to recapping this PSU.
Yes, I desoldered and removed it. Then I recapped the psu and the small board and reinstalled it as part of reassembly. I didn’t have my desoldering gun at the time, so I just used desoldering braid and it soaked it up nicely allowing the pins to slide out.
Good luck!
Well I got the power leads desoldered from the plugs and the board removed from the PSU case. I removed the top IEC C13 Monitor connector plug from the sheet metal PSU housing, but the little tabs that hold it in were super brittle and they broke off, so I'll be getting a new one of those when I resolder it all back together. You don't happen to know if there are any 614-0039 PSU recapping diagrams anywhere do you? I have the kit from Console 5 and will just match up the components with similar ones on the PSU board. It looks like the big giant caps on that PSU board are glued to the board. Were they glued to the PSU board that you recapped? Sorry for the elementary questions, I've recapped a few classic macs but this is the first Power Mac PSU I've recapped.
Dang it. Well the other day I had 3 Power Mac chassis with 3 different 614-0039 power supplies...and 3 of them were working. First the one in the 7500 died and started giving the "click click click" when pressing the power button. That's the one I have started recapping in comments above. Now I have a second one that was in a7600 chassis that was working the other day and I just swapped in a different logic board and I get the "click click click" of death. This totally reminds me of the "fwup fwup fwup" sound the Mac Plus analog boards would make. Ugh. Have others here with Power Mac 7200/ 7500/ 7600 models found their power supplies are very fickle? I know I know, 30 years old and all that....
BTW, thinking about it, I was thinking about my NeXT Cube Power Supply where I had to desolder a number of pins of a small PCB. Sorry for the confusion. I've done too many power supplies in the last 18 months.
Do you have a load on the supplies? I don't recall with this supply, but most switching supplies require a load to operate.
I have attached what I found (sorry for the lack of attribution, it is simply a file I downloaded from somewhere) for when I did my 7600 supply.
Most of the pieces were glued on my board (hence the reason for this thread as in removing the glue, a resistor got removed). Other than that resistor, the glue was fine. The glue was brittle. I fully desoldered the caps, then wiggled the caps, and they came out. I would then use needle nose pliers to try to remove some of the glue. The good news is that the replacement caps are (nearly) always smaller than the originals, so there weren't any fitment issues, and I left most of the glue in place.
By load on the power supply I would think HDs would count as a load. In both systems where the PSU refuses to power up but just makes a clicking sound there is a HD connected.
