TashMachine: Verilog IWM Clone
Tashtari
PIC Whisperer
Maybe you'll have to start calling me the CPLD whisperer... then again, maybe not. Either way:
Introducing... TashMachine!
Elevator Pitch
It's a behavioral clone of the Integrated Woz Machine, the ASIC that acts as the floppy controller in the Mac (and the Apple IIgs and IIc+, maybe others?), written in Verilog and sized to fit in an Atmel/Microchip ATF1508 CPLD.
Project Status
Showing first signs of life. It is able to boot the ITXPlus from a Floppy Emu. Much testing (and probably debugging) remains to be done.
Caveats
At the moment, the biggest point of bother is that what caused the code to go from nonfunctional to functional was... changing what signal was routed to an extra output pin for debug purposes. That means that something somewhere in the code is marginal and that's bad. The ATF150x CPLDs (or at least their associated toolchains) are kind of temperamental in this way, just ask @zigzagjoe.
What's Next
Well, I need to figure out the Heisenbug that I earlier mentioned, but I'm not exactly sure how to go about it. This is my first non-trivial Verilog/HDL project, and the tools I'm using aren't the sharpest ones out there. For those interested, I'm using an ancient version of Quartus II to synthesize the HDL code for a discontinued Altera CPLD and then using an Atmel/Microchip program called POF2JED to convert the output of Quartus II for use in an ATF1508. Extra pins are about as far as my debug capabilities go, and if those can't be relied on, well...
Cursed Testing Environment Photo
Not pictured: USB extension lead stretched across the desk to my workstation for the Bus Pirate that I'm using for JTAG.
Code
Soon...
Wonderfull achievement :) DCD support coming or the logic can't fit in the ATF ?
Actually, DCD support should come for free if the behavior of the IWM is being properly imitated. It's sort of misleading to say that DCD devices "pretend to be floppy drives", but, in a way, they do - they use the same communication channels as floppy drives do and, at the physical layer, the same data format. It's just that instead of a series of "nibbles" characterized by the fact that '1' bits are never separated by more than two '0' bits, they use a different encoding scheme that doesn't care about separation (since both ends of the connection are timed by high-precision oscillators rather than spinning rust).
Slightly tangential question: what would it take to upgrade a Plus to a SWIM? Is there a reason Apple never did it (apart from rewriting ROMs for the upgrade)?
Well, the SWIM is a proper superset of the IWM, so if you put a SWIM in it, the Plus will just use it as an IWM and ignore the extra functionality. The ROM would have to be upgraded. (If anyone wants to put a PLCC44 SWIM in a DIP28 socket anyway, contact me, I have PCBs for this.)
Also, I should probably get this out of the way since someone is bound to ask - I have no plans to write a SWIM clone at this time. As it stands, TashMachine takes up 127 of 128 macrocells in the ATF1508 and that's the largest CPLD that Atmel/Microchip make. To make a SWIM clone, I'd need an FPGA in a surface-mount package the size of a fingernail clipping paired with lots of level-shifting logic, and I'd have to set up a toolchain that requires an eight-terabyte download to install it and every time you start it the lights dim and it has to download four more terabytes of updates and bleah the very idea just makes me feel exhausted. =D
Ah, so just typical Apple "we didn't feel like it"...
