Turbo 040 won't fit in a Mac IIx?
So here's a weird one. I finally found a Daystar IIx adapter (pretty elusive, that one). I attach a Turbo 040, open up the IIx, aaand... it won't fit!! The card is too tall, i.e. the post that holds up the drive tray is in the way. I need maybe extra 5-7mm. This seems odd since the Turbo 040 is designed to work in the IIx. I guess I could cut a notch in the plastic post, but I'm just refusing to believe that they made a mistake when designing the adapter. Anybody have any idea as to what's going on here?
It fits fine in the Mac II because the adapter is angled and the card sits on top.
But in the IIx, the card is on the side. I can just BARELY fit a Powercache, but the Turbo is taller:
Not an expert on these by any means, but from the following link it appears there are four revisions of the Turbo 040, and I can tell from the photos even without an external scale reference they are all slightly different dimensions:
You appear to have the one at the very bottom which seems to be the tallest. The one directly above it, where the board edge is flush with the top of the ‘040 looks like it would probably fit a IIx.
Good call! I actually have three but they are all the same (oldest?) version - the one with the extra cache card on the back. My version definitely looks taller in the pictures. I guess I knew there were multiple versions but I didn't realize they were different sizes. I actually thought maybe they made multiple versions of the adapter and I got the wrong one. This is a relief since the adapter is actually much harder to find.
P.S. As a further confirmation, the manual that includes, among others, the IIx installation instructions, does have a picture of the newer version of the card. https://www.artmix.com/pdffiles/TurboIns_MN.pdf
