Can a PowerMac 8600/200 run in 1280x1024?
richj
I just picked up a PowerMac 8600/200 with 256MB. https://lowendmac.com/1997/power-mac-8600/ says that the video supports 1280 x 1024 at 8 bits with 2 MB VRAM but I'm unable to get the Monitors control panel to show anything over 1152x870, even when 256 colors or grays is selected.
I'm using a Dell 1905FP monitor which supports 1280x1024.
I've tried two different DB15-to-VGA converters: One with no dip switches, which results in no video at all. The other with 6 dip switches with listings for 8 different modes on the back (21" multimode, 17" multimode, 13" multimode, VGA/SVGA, 21" 1152x870, 19" 1024x768, 16" 832x624, and 13" 640x480). I currently have the first mode selected.
Perhaps I need a different DB15 to VGA converter?
To be sure, gave this a try on a ten-switch adapter with a PM7200's built in video, and was finally able to see the "missing" 1280x1024 mode as well. The 21" Multiscan (MODE 1 if applicable) works great for getting the desired behavior out of the sense lines.
I see 640x480, 832x624, 1024x768, and 1152x870.
Use the Control Strip instead of the Monitors control panel to see the 1280x960 and 1280x1024 options.
The Monitors control panel doesn't show those options because they are not marked as safe? The SwitchRes software may be able to fix that.
Mystery solved. The 1280x1024 resolution appears in the Monitors & Sound control panel, but not in the Monitors control panel, so I was looking in the wrong place. With the dip switches set to 21" multimode I can now see all of the following in Monitors & Sound: 640x480, 832x624, 1024x768, 1152x870, 1280x960, and 1280x1024. The two 1280 modes are missing from the Monitors control panel.
