New Project: DoubleVision SE/30 Card
Hello Mac community,
since I have gotten my first actual Macintosh last month (LC475), I must admit that the "Mac Bug" has bitten me, which is why I have now also pushed the trigger on getting a Macintosh SE/30 yesterday.
In order to have fun with it, I decided to port one of my other Amiga projects to the SE/30, therefore, I would like to announce today that I have started to develop a new graphics card for the SE/30 called:
DoubleVision SE/30
Technically, it is very much a Macintosh port of my Amiga graphics card, the P-Vision, but with some Mac SE/30 specific feature enhancements. ;)
So what can it do? Well, here is the feature List:
  • HDMI video plug using DVI video signalling
  • 32MB VRAM framebuffer, clocked at 165MHz
  • Supports 1bit,2bit,4-bit,8bit,15bit,16,bit and 32bit color depths
  • All standard VGA and MAC resolutions, supporting up to 1280x1024@60p AND 1920x1080@30p
  • Fast 64-bit BitBlt engine, pushing up to 130 Mio Pix/s (8bpp)
  • 32 KB internal ROM for graphics drivers
  • Firmware can be fully upgraded on the host system (via "FlashFPGA App" running on MacOS)
  • Special MAC SE/30 features:
    • Card can work in dual-mode (second monitor to the SE/30 internal monitor) or route the SE/30 internal video output to HDMI
    • If MAC is booted, and no HDMI is connected, framebuffer memory is added as 32 MB system memory
    • Eleborate write-through cache to minimise read/write latency to VRAM
    • Makes full use of 68030 2-cycle 32-bit synchronous bus termination - yielding up to 32MB/s host memory performance using 16MHz bus!
I have seen that MAC SE/30 graphics cards using old and outdated graphics chips fetch high prices on the collector's market, so here is my offer to the community to provide a much more modern and better solution.
The card itself is low-profile and it has an internal HDMI port, which can be put outside of the SE/30 via a small bracket.
As I said, most of the development is already done, as the designs works great on the Amiga, therefore I expect that the most challenging part for me is to write the graphics ROM driver for the MAC in order to enable the display output. I have already started to look into this direction. ;-)
So for now, let's start with a first render of the board PCB, which I expect will be nearly identical to the final PCB.
As always, questions, comments, etc are always welcome. :)
Dedicated chip(s) for video and/or acceleration, or are you using a FPGA for everything ? The rendering show quite a small chips for a FPGA (... but then I went a bit overkill :-) I could probably get two Full HD output if I really wanted to... ).
@zigzagjoe has a SE.30 video board with a dedicated chip, the 30Color.
My IIsiFPGA is targeted at the IIsi; should work in a SE/30 but it might not physically fit. You can find the source code for the DeclROM in the VintageBusFPGA repository on GitHub. So is the firmware for the custom VexRISCV core used for acceleration. The acceleration INIT and the audio driver (when using the PHY with 'true' HDMI signalling, instead of the DVI-like PHY - though this last one supports many hardware resolution via PLL reconfiguring while the 'true' one is just one hardware resolution + windowbonxing) is in the NuBusFPGA repo. Maybe it can help getting you started with the software (... mine is GPL BTW).
Acceleration is the PITA part. You need to hack into QuickDraw in a very ad-hoc fashion, peeking and poking in memory... it's not pretty. That's why I only did blitting, when the hardware could theoretically do all of it (it's just a CPU and some C code!), same as the 8*24GC board did.
Edit: forgot to say, there's also a Rom patch for the IIsi to add an extra memory bank to use the FPGA spare memory as extra RAM. Testing an additional 240 MiB of RAM at boot takes a loooooong time.
If only this would be also compatible with IIsi and A/UX ... 😇
If the driver is well-behaved it ought to be, at least under A/UX 3. A/UX 3 runs the mac display driver in a kind of demented cradle, lying to it frantically to try to stop it realising it's not running under MacOS. Note though that this is not the same demented cradle that other bits of Mac software run in (that's demented in a rather different way) so things like anything patched in an INIT won't work. The driver will have to be self-contained, as it should be.
As with all my projects, they are FPGA based. Inside the FPGA, I'm using a full 64-bit datapath for everything, and a highly pipelined memory transaction arbiter, controller, display engine and BitBlt engine.
Even without using the BitBlt engine, at least on Amiga, the design is fully usable even using an 68EC020 CPU at 14.3MHz using 8-bit color depth at 1920x1080. I expect that at least the same can be achieved on a stock SE/30, or even better using the full 32-bit synchronous data path.
Wow, thanks a lot! :) I have started to read the "Designing Cards and Drivers for the Macintosh Family" guide, and have seen that there is actually exaple code for a skeleton graphics driver present there.
It's actually very much the same on the Amiga as well. The OS provides hardware acceleration functions for the Amiga Blitter in the "graphics.library", but no interfaces to defer the functions to a different rendering target. That's why, in the 90's, several frameworks were developed to add this missing layer, which Commodore did not get around to implement. And it works really well!
I can imagine, luckily, my card provides only 32MB of VRAM. ;)
Thanks for your help!
Hehe, me too. Much more fun to be able to fix/update/improve/extend the design even after the hardware is done :-)
.Inside the FPGA, I'm using a full 64-bit datapath for everything, and a highly pipelined memory transaction arbiter, controller, display engine and BitBlt engine.
Neat. Is it purely for your own stuff or di you open-source it ?
My design is less efficient - it's essentially a CPU-less soft-SoC using Litex, with a bridge from the original bus (SBus originally, then NuBus, '030 and '040). Main bus is just a 100 MHz Wishbone, and the peripherals are mostly from Litex (e.g. the memory controller is LiteDram). I hadn't done any hardware before the original SBusFPGA, Litex was the reason I was able to do some "sophisticated" stuff.
The original accelerator was going through the Wishbone, but I eventually implemented a dedicated 128-bit bus from the VexRISCV D-cache to the LiteDram arbiter. Probably overkill - i meant to try NaxRISCV as the accelerator, but last time I looked it was still a bit too feature-rich (my version of the VexRISCV is really just a glorified micro-controller with some custom instructions to better support X11 acceleration including XRender and unaligned blitting in QuickDraw).
1920x1080 is OK on '030 in 8-bits or less on e.g. a IIsi, or anything with a NuBus slot (which is the bottleneck), but not fast. 32-bits is too slow without acceleration, and even with acceleration it's not super comfortable (I should so more acceleration...). It's much better on the QuadraFPGA where the FPGA connects directly to the '040 bus - BW and latency are almost good enough, and with acceleration it's usable even in 32-bits. Also fine on SBus using EXA/XRender on my SPARCstation 20 (on my incredibly large back-burner, there is supporting USB and accelerated X11 in NetBSD/mac68k...).
Though truth be told, unless doing vintage Photoshop, there's not mych reason for 32-bits on vintage Macs. If I had the skill for the PCB, I'd have a go at a much cheaper version with a Spartan-7 (instead of the Artix-7) with 1024x768/32, 1280x1024/16 and 1920x1080/8 as the targets. But designing the DDR[23] interface is too complex, and Spartan-7 aren't really designed to support single-sided (read: assembled for cheap by JLCPCB!) board with their decoupling requirements :-( But then I guess it's no longer a problem as you're about to fill that niche anyway :-)
The example code is ... a starting point :-/ I had a lot of trial-and-error to figure out how everything worked in various OSes, and the godsend for me was QEmu. I just hacked a version of QEmu with could emulate a Q800 to create a model of my (unaccelerated) device, and developed the ROM on that. It helped a *lot*.
Even if not perfect, that sounds a bit more comfortable than the horror that is QuickDraw acceleration :-/ There's no provision for acceleration at all up to at least MacOS 8, and the functions you can substitute for (by gijacking the traps...) are quite high-level. I highly recommend sorting out all the dumb framebuffer stuff before even thinking about acceleration... it's a really deep rabbit hole to get into.
Definetely, and it's also my preferred modus operandi, since I come from the semiconductor industry. So for me, FPGA is real hardware. ;)
I'm considering to open source it - at least the PCB files and software. I'm doing this for fun, not for any commercial "gains" (which is impossible, given the amount of unpaid engineering hours being spent on such projects).
Which is completely okay. You do this for fun, possibly to gain new skills and experiences, and it's often better to get anything out first, rather than waste time on perfectionism. Due to my experiences, I usually have a good feeling about what resources are needed for a specific design. In this case, I'm using an FPGA with 8-16K LEs, depending on if I can make the blitter work reasonably well in a Mac environment. On Amiga, it works really well.
Going RISC-V would also be my choice if I wanted to have a more flexible design. The blitter itself is actually quite close to a typical 90's bit blitting engine you would find in such designs from ATI, S3 or Cirrus Logic.
32-bit becomes usable starting with a 50MHz 68030. On the Amiga, the bottleneck of my card is actually the PCMCIA bus, which maxes out at 8.5 MB/s. But since, on the SE/30, the full 32-bit synchronous bus is exposed, I really think this will work much better. Then it's mostly a matter of how well QuickDraw if optmizised for software rendering - which I believe might be superior to the software renderer mode of the Amiga graphics card framework.
Hehe, you seem to be quite a busy and passionate individual! :) I'm glad that I joined this Forum, quite interesting things going on here.
My attempt is to max-out a relatively constrained design, so I pay very much attention to things like memory arbitration, and designing the memory controller in a way to provide the right transaction scheduling strategy to max out the DRAM interface. Doing this, you will be surprised how much can be achieved using only a 16-bit SDR SDRAM chip. I'm also trying to keep it "solderable" so that people can manufacture their own cards.
Again, thanks a lot for offering your valuable work. As I said, once I am finished, I'm actually going to open source this design as well.
Sure, the blitter is just part of the design, because it's already existing from the Amiga use-case.
Yes, FPGA feels a lot more like hardware than software emulation. And things like PiStorm and other feel a bit off to me - when going SW, might as well go into it fully like QEmu or MAME.
I am in the semiconductor industry as well, on the design side - waiting for a chip back from TSMC at the moment - which I joined a couple of weeks after the Covid lockdown started in France back in 2020. At that point, locked at home and needing to understand the vocabulary of my true hardware colleagues (so many words that seem to mean the same things than to SW people but not really...), the SBusFPGA started with just the hope of blinking a Led someday :-) But I never encountered a rabbit hole I didn't want to explore and map fully... and I think I'm still the only person in the world to have USB and HDMI on a SPARCstation :-)
BTW, have you looked at the open PDKs and open-source EDA stuff ? Nowhere near the level of leading-edge, but the SKY130 should be able to produce some interesting replica/update of 80s and 90s chips...
Hehe, due to my lack of experiences, I just over-engineer everything - or at least I think I do! :-)
Though I'm not the worst - I use an Artix-7 35T in the *FPGA, and I have considered projects with 100T. I know of a (non-pubic) project of another FPGA-based video board for the SE/30, and they used a Kintex-7 325T... that FPGA will host quite a bit of hardware! (... if you have the license for Vivado).
I tried to design one, but misaligned accesses was a bit much and I couldn't figure it out (based on, of all things, a crypto engine...). That's when I switched to a simple CPU core. It's also more versatile ; XRender tends to use funky arithmetic to implement acceleration - it has a datatype over 8 bits that represent [0-1.0], so (255*255) is supposed to output 255... So I added an instruction to do four (a*b)/255 in a 32-bits register used as 4*8-bits (SIMD). I also added double-register (64-bits) load/store to improve bandwidth a bit. But it's probably not very area-efficient for its purpose.
Well, I don't know anything on the Amiga side, but while the B&W QD code on the 68000 was very efficient, I'm not so sure about all the extra stuff they added in Color QuickDraw... and it's a complete mess as an implementation, when judged by modern standard.
I come from a HPC background; we do optimize software (and a lot of it is still Fortran, so no tmany yuoungsters going into it ;-) ), but otherwise we just throw hardware at the problem :-) The only people that are worse (way worse) than us are the AI people. We still count in thousands of CPU cores; they moved on to counting megawatts and gigawatts directly...
Makes me think of a question: you connect the SDRAM to the CPU bus directly and use the FPGA as a memory controller? [which would explaing getting away with just a QFN?] Or is the CPU <=> memory path going through the FPGA? I use the second option (so all the hard PCB stuff is on a FPGA board I just buy), but readback latency sucks. It also burns pins on the FPGA to support the parallel busses, requiring a big FPGA board and limiting the number of peripherals you can add on the FPGA (if you have a biggish FPGA, might as well make the board multi-functions!).
I know SDRAM can be used on those vintage CPU (there's a SDRAM board for the SE/30 on this very forum, and before that I saw some Amiga accelerators and homebrews also using SDRAM), but I never finished my attempt at implementing it. The timing trickery to get the appropriate setup/hold time from the SDRAM is still beyond me.
Never been good at it, terrible eyesight that keeps getting worse => JLCPCB (and before that, SeeedStudio) is my lifesaver. I still can do 2.54mm pitch through-hole, and I did 1.27mm by taking the time not too long ago (SBus connector). JLCPCB does 0402s for dirt cheap, so usually I just pay them to do it for me...
It's quite a challenge to acquire new skills, especially when you are basically working in an isolated environment without getting to meet your colleagues F2F. Has been quite a challenge for me as well, but in the meantime, I have gotten used to it.
It's then "only" a matter of producing this ASIC. ;)
Yeah, same stuff happened on the Amiga as well, and my answer to that was the P-Vision, showing I can basically do the same things on a $30 FPGA in TQFP package. ;-) I guess that's why I am also attached to retro designs, because it remebers us that basically most of the work can be accomplished with a lot less resources.
And it's also a good education for my kids, who will have the benefit of still learning how computers REALLY do work.
I tried to design one, but misaligned accesses was a bit much and I couldn't figure it out (based on, of all things, a crypto engine...). That's when I switched to asimple CPU core. It's also more versatile ; XRender tends to use funky arithmetic to implement acceleration - it has a datatype over 8 bits that represent [0-1.0], so (255*255) is supposed to output 255... So I added an instruction to do four (a*b)/255 in a 32-bits register used as 4*8-bits (SIMD). I also added double-register (64-bits) load/store to improve bandwidth a bit. But it's probably not very area-efficient for its purpose.
If it gets the job done, why complain. ;-) Your next attempt will benefit from having it already done by yourself.
Very simple, SDRAM is connected to FPGA, and the whole address / data bus of the 68030 is multiplexed (hence the sh*tload of bus drivers on the PCB). This basically yields the same performance as using a non-multiplexed bus, AND, I have full access to all data and adressbits of the CPU. Meaning, I can implement an efficient write-buffer strategy to sustain, at least, the maximum write performance to VRAM.
For reads, I'm planning to use the block ram to implement a small L2 cache.
Well, SDR SDRAM is way more forgiving in this regard than DDR2/3/4/5 designs. ;-) On P-Vision, I can reach 165MHz memory bus without a sweat. You have, of course, to pay attention to timing constraining your design reasonably well (my memory controller can even run at 190Mhz - so there is still enough breathing room.)
Funny you mention this, because today, I picked up my new glasses. :)
I think it's the issue is skills for now - having people involved that know how to do all the steps "after" HDL design - DFT, verification, etc., all the way to the packaging and package testing. Even when some of those steps are done by a professional house, you still need knowledgeable people to handle/control the steps in the flow.
For costs, they don't do SKY130 (yet), but EuroPractice has GF180 with the open-source PDK at less than 1000€/mm^2 (min 6 mm^2) for a small MPW run (excluding packaging I think). Not yet JLCPCB-cheap, but not entirely out of range for motivated hobbyists either.
There's still universities/research centers doing tape-outs - e.g. ETH Zurich has a very long list. Maybe open-source PDKs and Europractice will help push more students (and universities) into doing the same; and maybe they'll need project ideas... The geopolitical situation also will likely push for those skills to be available/common in more countries than they used to.
I'd say most of the pieces are there. I don't see it happening in 2026, but I wouldn't be surprised to see a retro-computing project trying to do a new chip (maybe with a Kickstarter or similar) before 2030 is over. One can hope :-)
Oh, that's the trick. Looked into it after the discussion on the '040 muxed-bus mode, but that's supported natively only on the full '040 so not super useful (love me a 3V3 static '040V). For timing reason, I assume you use some fast FET-based switches such as CB3T? I use those in many projects (expensive but convenient...) but only as pass-through, not as actual switches... so everything is handled in the gateware rather than hard-wired. Hence the stupid-big FPGA to get enough pins :-(
Thought of that, never actually implemented it. Readbacks are important but not critical... All writes are fire-and-forget though, pushed into a FIFO immmediately. I have on my TODO list to change my current implementation, as now it kinda sucks - the reads (which are going directly to the Wishbone) have to wait for the write FIFO to be empty to avoid memory coherency issue. For the emulated Sun-3, I did it the "proper" way (?) with a request FIFO handling R+W and a response FIFO for R, so reads can be pushed immediately after writes with no extra delay and no ordering issue (and it makes CDC easier as it's all handled in the FIFOs, no Wishbone CDC as in the current *FPGA design).
1920x1080@60 Hz already needs ~125 MB/s read bandwidth just to display. At 16-bits / 165 MHz you get 330 MB/s peak, minus the system inefficiency so that's what, 250-260 MB/s delivered to the FPGA? Enough but as you said, constrained - can't waste much of that bandwidth if you want a good acceleration engine connected to the framebuffer as well!
My ZTex board does 400 MHz DDR3 16-bits so 1600 MB/s peak, which seems overkill, but 1920x1080@60 is ~500 MB/s for 32-bits TrueColor already so it's needed.
So, design finished, PCBs ordered.
That was quick! I usually take months between first draft and production, just fiddling and "improving" and double-checking :-)
Just to give you some pointers, here is my same graphics core running on the Amiga. It's using PCMCIA Interface of the Amiga 600/1200, but is COMPLETELY usable.
Yes, even for MAC, if you run ShapeShifter. ;)
But here, we are going to run this on original MAC hardware.
Screenshot 2026-01-21 115824.pngScreenshot 2026-01-21 115809.pngScreenshot 2026-01-21 115854.png
What the core also has, but might be of no use for MAC users:
* 64x64 Hardware sprite for mouse pointer
* Full display co-processor to support Amiga-style draggable screens. In short: on any given vertical raster line, you can define "display slices" which have their own resolution and color depth.
Indeed there is no support for hardware cursor in 6/7/8. I also have the hardware cursor (albeit smaller at IIRC 32x32, a clone of what available in Brooktree DACs in SPARCstations, also with a limited number of colors) but it's only useful in X11.
At that size, if the sprite is full-color (same depth and CLUT as the display), then it could replace the SW implementation. Maybe it could be used by hijacking some of the QD functions - but it's likely going to be quite difficult to implement.
What does that mean and what is it used for on Amigas, practically?
Thinking of screens, plural, on Mac, QD basically define a massive 64Ki*64Ki (16-bits signed values) area, and each display is just a small subset of that - obviously the primary screen is anchored at (0,0). They can have their own resolution and depth independently. It's very convenient for the user but as mentioned previously, makes it less than obvious what's going on if you don't go through QD.
(tangent) One of my favourite weirdo old computers is the Whitechapel MG-1, a Unix workstation from the early '80s. The mouse is handled in hardware by an I/O co-processor (a microcontroller basically) that takes care of all the "human interface devices", which I guess is how the Lisa does it too. Unlike the Lisa, the MG-1 keeps the mouse position in discrete hardware latches on the mainboard, which is to say actual 74-series DIP ICs whose only job is to store where the mouse is. I am very fond of my MG-1 and would never wish to damage it, but I always found it funny that I could give the board the HAL 9000 treatment, pull out some of those latches, and literally remove the computer's ability to move the mouse left and right or up and down.
