Macintosh SE/30 replace processor MC68030RC16B to MC68030RC30C
Plottem
Good morning, I am restoring a Macintosh SE/30 that I received as a gift. The case is the following, the motherboard did not have the Motorola MC68030rc16 shock type processor (someone removed it to sell the gold) I bought the same one but the seller sent me a MC68030RC30C, instead of the MC68030rc16B, I assumed that there would be no problem in that in instead of 16mhz I had 30mhz. I recap the board and got it working. The equipment works but the resistor R29 (12 Ohm, 2w) of the analog board gets very hot!!! and I'm afraid it might burn. Do you think that the increase in temperature in this resistor could be due to the difference in MHz between the original processor and the one that I have installed? Greetings
You should be fine with your 30MHz processor, if anything, it will use less power and run cooler.
I suspect the resistor is meant to run that hot.
Thanks for your answer, the temperature gets too high, you have undone the silicone that holds the fan wires, and these are getting shiny, and it smells like burning.
I suspect it isn't because of your CPU, unless the CPU is faulty. Try powering on without the CPU installed and see if the resistor still gets hot. If it does, search near the resistor (for things electrically connected) for a part that has shorted.
Can you desolder one side of the resistor and measure if it has the correct resistance?
Good idea!! I'll do the test! thanks!
You probably know that already, but for the sake of completeness: your new CPU is _capable_ of 30 MHz operation, vs. the original one that would only be rated for 16 MHz for whatever reasons. However, in the SE/30, this CPU will still _run_ at the 16 MHz, as dictated by the CPU clock. This is totally safe from the CPU point of view (as mentioned by @Phipli, if anything it will save power/energy as the 30-MHz rated CPU is likely running on less power/cooler than the 16-MHz rated one), but it doesn't help with performance.
Can I use a Motorola MC68030RC33B in an SE/30?
The CPU my SE/30 came with was a XC68030RC16B, which seems to be very rare and I can't find an exact replacement.View attachment 93572
Yes you can - behaviour will be identical as far as it matters.
The speed is just the grade - the part is the same, just approved to be operated at higher speeds... In computers that run at higher speeds.
Plug it in and enjoy.
Thank you so much!
The XC prefix on moto parts means preproduction/early access samples. I vaguely recall Apple and one other vendor at least put XC parts into production computers because they got super early access and were satisfied with performance/stability.
Thanks for the reply. On ebay there are a few loose SE/30 boards for sale, from 1987-1988, early SE/30's like mine, where the boards look new still but they all have the simasima pattern and they all have the XC68030RC16B CPU's.
I am wondering if the XC, like you said, was an early chip that fails early too, as they switched to the MC68030RC16B not long afterwards.
I have taken all of the steps provided by the excellent Simasima Repair Guide, found here:
- to troubleshoot the issue - and my board and all the traces/chip functions seem to be in perfect working order, except the CPU 'walking the bus'; not one ROM Address line has a clean square wave.
I should have the new MC68030RC33B next Monday, I'm really hoping this is the issue - it almost has to be at this point after all of the troubleshooting.
Thank again for the info!
I’ve never heard of any problems with 68k Motorola chips with XC prefixes. I think most of the ones Apple shipped were labelled XC, since the validation process could take quite some years.
I very much doubt it. I mean, sure it's a weird coincidence what you're seeing, but lots of equipment was shipped with XC parts. Is it possible that there are bad batches? Sure, compare date codes on the bad boards and see if they're all clustered. But I really don't think it likely that these are inherently bad parts, it's just an interesting note that they are _earlier_ parts. Gathering the QA data to move them from XC to MC status took time, that's all.
I don't recall seeing XC68000s (even the Lisa boards I've seen had MC68000s) but for sure I've seen plenty of XC030 and XC040 CPUs in Apple gear. I, too, have not heard of any systemic problems with the parts, it's just an interesting historical note.
I should have the new MC68030RC33B CPU shortly, I'll follow up when it arrives.
If in fact my XC is bad, what would have killed it?
Why would Apple switch to the MC68030RC16B, if the XC was good enough? What's the actual difference?
Summary of troubleshooting and current issues with my SE/30 board, CPU not 'walking the bus':
I have never seen a single failed 68030, I have quite a few. You're over thinking things.
Has the board been recapped by the way? That is a requirement for SE/30s as the capacitors they were built with leak a corrosive fluid over time. If it hasn't been done, you might want to talk to Amiga of Rochester if you're in the US. They'll recap and repair.
CayMac Vintage on Youtube has experienced a bad XC CPU, in a video of his about 7 months ago.
Every board in this unit has been recapped. I included a link to a thread showing everything that's been done to it, above.
The CPU is not walking the bus, I have a scope and am looking at every Address line in the ROM slot, A2-A31, there is no clean square wave with or without the CPU inserted:
This thread details all that has been done so far in a brief summary:
Or a longer thread here:
It is entirely possible your CPU has failed. But if it has, it is not because it is an XC part, it is because in time all things will fail. The fact that your specific one that has failed has XC on the top of it is not really meaningful here, it's just noise.
