Photo Request : 5500, 6500 and TAM Logic Board
And apparently there is a 25000 character limit on the forum, but LibreWriter says my post was only around 24000.. Oh well. You probably don't need a new device-dump-tree but for completeness...
Code:
A > dump-device-tree
PROPERTIES:
name                    device-tree
model                   Power Macintosh
compatible              AAPL,e411
                        MacRISC
AAPL,cpu-id             10000000
#address-cells          00000001
#size-cells             00000001
clock-frequency         02FAF080
METHODS:
make-cpu-properties             dma-sync        dma-map-out     dma-map-in      dma-free
dma-alloc       map-out         map-in          decode-unit     close           open
?pdm
/PowerPC,603@0
PROPERTIES:
name                    PowerPC,603
device_type             cpu
reg                     00000000  00000000
cpu-version             00071201
clock-frequency         11E1A300
timebase-frequency      00BEBC20
reservation-granularity 00000020
tlb-sets                00000020
tlb-size                00000040
d-cache-size            00004000
i-cache-size            00004000
d-cache-sets            00000080
i-cache-sets            00000080
i-cache-block-size      00000020
d-cache-block-size      00000020
existing                00000000 80000000 80000000 80000000
available               00000000 F2000000 F4000000 0B800000 FF900000 00300000
translations            F2000000 00010000 F2000000 00000028 F2800000 00001000 F2800000 00000028
                        F2C00000 00001000 F2C00000 00000028 F3000000 01000000 F3000000 00000028
                        F8000000 00001000 F8000000 00000028 FF800000 00100000 00400000 00000010
                        FFC00000 00400000 FFC00000 00000000
METHODS:
translate       modify          unmap           map             release         claim
close           open
/chosen@0
PROPERTIES:
name                    chosen
stdin                   FF8DA640
stdout                  FF8DA500
memory                  FF8DD840
mmu                     FF8DD900
bootpath                00
bootargs                00
/memory@0
PROPERTIES:
name                    memory
device_type             memory
reg                     00000000  08800000
available               00000000 00400000 00500000 08300000
METHODS:
release         claim           close           open
/openprom@0
PROPERTIES:
name                    openprom
model                   Open Firmware, 2.0.3
relative-addressing
/AAPL,ROM@FFC00000
PROPERTIES:
name                    AAPL,ROM
device_type             rom
reg                     FFC00000  00400000
METHODS:
load            open
/options@0
PROPERTIES:
name                    options
little-endian?          66616C73 6500
real-mode?              66616C73 6500
auto-boot?              66616C73 6500
diag-switch?            66616C73 6500
fcode-debug?            66616C73 6500
oem-banner?             66616C73 6500
oem-logo?               66616C73 6500
use-nvramrc?            74727565 00
real-base               FFFFFFFF
real-size               00100000
virt-base               FFFFFFFF
virt-size               00100000
load-base               00004000
pci-probe-list          FFFFFFFF
screen-#columns         00000064
screen-#rows            00000028
selftest-#megs          00000000
boot-device             2F414150 4C2C524F 4D00
boot-file               00
diag-device             66643A64 69616773 00
diag-file               00
input-device            74747961 00
output-device           74747961 00
oem-banner              00
oem-logo                00
nvramrc                 64657661 6C696173 20736372 65656E20 2F62616E 6469742F 4154592C 426C7565
                        53746172 40450D63 706F6B65 20306137 20306633 30303030 33320D63 706F6B65
                        20303933 20306633 30303030 33330D63 706F6B65 20303365 20306633 30303030
                        33610D0D 00
boot-command            626F6F74 00
/aliases@0
PROPERTIES:
name                    aliases
pci1                    2F62616E 64697440 46323030 30303030 00
fd                      2F62616E 6469742F 6F686172 652F7377 696D3300
kbd                     2F62616E 6469742F 6F686172 652F7669 612D6375 64612F61 64622F6B 6579626F
                        61726400
mouse                   2F62616E 6469742F 6F686172 652F7669 612D6375 64612F61 64622F6D 6F757365
                        00
screen                  2F62616E 6469742F 4154592C 426C7565 53746172 404500
ttya                    2F62616E 6469742F 6F686172 652F6573 63632F63 682D6100
ttyb                    2F62616E 6469742F 6F686172 652F6573 63632F63 682D6200
scsi                    2F62616E 6469742F 6F686172 652F6D65 736800
scsi-int                2F62616E 6469742F 6F686172 652F6D65 736800
ata                     2F62616E 6469742F 6F686172 652F6174 6100
ata-int                 2F62616E 6469742F 6F686172 652F6174 6100
/packages@0
PROPERTIES:
name                    packages
METHODS:
open
/packages@0/deblocker@0,0
PROPERTIES:
name                    deblocker
METHODS:
empty-buffers   write           read            seek            close           open
/packages@0/disk-label@0,0
PROPERTIES:
name                    disk-label
METHODS:
load            offset          close           open            file-str        part-str
dma-free        dma-alloc       max-transfer    block-size      write-blocks    read-blocks
/packages@0/obp-tftp@0,0
PROPERTIES:
name                    obp-tftp
METHODS:
dma-free        dma-alloc       max-transfer    block-size      read-blocks     load
read            close           open
/packages@0/mac-files@0,0
PROPERTIES:
name                    mac-files
METHODS:
load            close           open
/packages@0/mac-parts@0,0
PROPERTIES:
name                    mac-parts
METHODS:
load            close           open
/packages@0/aix-boot@0,0
PROPERTIES:
name                    aix-boot
METHODS:
load            close           open
/packages@0/fat-files@0,0
PROPERTIES:
name                    fat-files
METHODS:
dir             load            open            close           read-blocks     seek
read            dma-free        dma-alloc       max-transfer    block-size
/packages@0/iso-9660-files@0,0
PROPERTIES:
name                    iso-9660-files
METHODS:
load            close           open            dir             read            offset
seek            read-blocks     block-size      dma-free        dma-alloc       max-transfer
/packages@0/xcoff-loader@0,0
PROPERTIES:
name                    xcoff-loader
METHODS:
init-program    close           open
/packages@0/terminal-emulator@0,0
PROPERTIES:
name                    terminal-emulator
iso6429-1983-colors
/bandit@F2000000
PROPERTIES:
name                    bandit
device_type             pci
model                   AAPL,343S1126
AAPL,interrupts         00000016
reg                     F2000000  02000000
#address-cells          00000003
#size-cells             00000002
clock-frequency         01FCA055
slot-names              0000E000 41310042 31004331 00
ranges                  02000000 00000000 F3000000  F3000000  00000000 01000000
                        01000000 00000000 00000000  F2000000  00000000 00800000
                        02000000 00000000 80000000  80000000  00000000 10000000
                        02000000 00000000 90000000  90000000  00000000 10000000
bus-range               00000000 00000000
METHODS:
encode-unit     decode-unit     dma-sync        dma-map-out     dma-map-in      dma-free
dma-alloc       map-out         map-in          close           open            probe-slots
req-io-addr     alloc-io-addr   align-io-addr   req-mem-addr    alloc-mem-addr  align-mem-addr
map-range       add-range       make-assigned-addresses         allocate-addresses
add-package     init-packages   config-l!       config-l@       config-w!       config-w@
config-b!       config-b@
/bandit@F2000000/ohare@10
PROPERTIES:
name                    ohare
device_type             dbdma
model                   AAPL,343S0172
reg                     00008000 00000000 00000000  00000000 00000000
                        02008010 00000000 F3000000  00000000 00100000
assigned-addresses      82008010 00000000 F3000000  00000000 00100000
ranges                  00000000  02008010 00000000 F3000000  00100000
vendor-id               0000106B
device-id               00000007
revision-id             00000002
class-code              00FF0000
min-grant               00000000
max-latency             00000000
devsel-speed            00000001
METHODS:
dma-sync        dma-map-out     dma-map-in      dma-free        dma-alloc       decode-unit
close           open            init-media-bay  enable-scsi-terminators
/bandit@F2000000/ohare@10/mesh@10000
PROPERTIES:
name                    mesh
device_type             scsi
model                   AAPL,343S1146
reg                     00010000  00000100
                        00008000  00000200
AAPL,interrupts         0000000C 00000000
AAPL,connector          scsi
METHODS:
show-children   set-tid-lun     decode-unit     close           open            dma-sync
dma-map-out     dma-map-in      dma-free        dma-alloc       retry-cmd       error?
db-rem          do-cmd          reset-scsi      set-timeout     mesh-iooffset   mesh-dmaoffset
/bandit@F2000000/ohare@10/mesh@10000/sd@0,0
PROPERTIES:
name                    sd
device_type             block
METHODS:
load            write           read            seek            close           open
write-blocks    read-blocks     max-transfer    block-size      dma-sync        dma-map-out
/bandit@F2000000/ohare@10/mesh@10000/st@0,0
PROPERTIES:
name                    st
device_type             byte
METHODS:
load            seek            close           open            write           read
write-blocks    read-blocks     block-size      max-transfer    write-eof       dma-free
dma-alloc       dma-sync        dma-map-out     dma-map-in
/bandit@F2000000/ohare@10/escc@13000
PROPERTIES:
name                    escc
device_type             escc
reg                     00013000  00001000
                        00008400  00000400
ranges
METHODS:
/bandit@F2000000/ohare@10/escc@13000/ch-a@13020
PROPERTIES:
name                    ch-a
device_type             serial
AAPL,connector          modem
reg                     00013020  00000020
                        00008400  00000100
                        00008500  00000100
AAPL,interrupts         0000000F 00000004 00000005
METHODS:
write           read            read-ahead      close           open
/bandit@F2000000/ohare@10/escc@13000/ch-b@13000
PROPERTIES:
name                    ch-b
device_type             serial
AAPL,connector          printer
reg                     00013000  00000020
                        00008600  00000100
                        00008700  00000100
AAPL,interrupts         00000010 00000006 00000007
METHODS:
/bandit@F2000000/ohare@10/awacs@14000
PROPERTIES:
name                    awacs
device_type             sound
reg                     00014000  00001000
                        00008800  00000100
                        00008900  00000100
AAPL,interrupts         00000011 00000008 00000009
/bandit@F2000000/ohare@10/swim3@15000
PROPERTIES:
name                    swim3
device_type             block
AAPL,connector          floppy
reg                     00015000  00001000
                        00008100  00000100
AAPL,interrupts         00000013 00000001
METHODS:
load            read            seek            eject           close           open
read-blocks     max-transfer    block-size      dma-sync        dma-map-out     dma-map-in
dma-free        dma-alloc
/bandit@F2000000/ohare@10/nvram@60000
PROPERTIES:
name                    nvram
device_type             nvram
reg                     00060000  00020000
existing                00000000 00002000
/bandit@F2000000/ohare@10/ata@20000
PROPERTIES:
name                    ata
device_type             ata
AAPL,connector          ata
compatible              ohare-ata
reg                     00020000  00002000
                        00008B00  00000200
AAPL,pio-timing         00000526 00000085 00000025 00000025 00000025 00000000 00000000 00000000
AAPL,interrupts         0000000D 00000002
METHODS:
close           open            ata-command     atapi-command   reset-atapi-bus reset-ata-bus
use-ata-interface               use-atapi-interface             set-timer       set-device-id
/bandit@F2000000/ohare@10/ata@20000/ata-disk@0,0
PROPERTIES:
name                    ata-disk
device_type             block
METHODS:
load            write           read            seek            open            close
write-blocks    read-blocks     block-size      max-transfer    dma-sync        dma-map-out
/bandit@F2000000/ohare@10/via-cuda@16000
PROPERTIES:
name                    via-cuda
device_type             cuda
reg                     00016000  00002000
AAPL,interrupts         00000012
METHODS:
get-mouse       read-kbd        close           open            read            write
/bandit@F2000000/ohare@10/via-cuda@16000/adb@0,0
PROPERTIES:
name                    adb
device_type             adb
AAPL,connector          adb
METHODS:
close           open
/bandit@F2000000/ohare@10/via-cuda@16000/adb@0,0/keyboard@0,0
PROPERTIES:
name                    keyboard
device_type             keyboard
reg                     00000000 00000000  00000000
METHODS:
read            close           open            reset           get-key-map
/bandit@F2000000/ohare@10/via-cuda@16000/adb@0,0/mouse@1,0
PROPERTIES:
name                    mouse
device_type             mouse
reg                     00000001 00000000  00000000
#buttons                00000001
METHODS:
get-event       close           open            mouse-button    mouse-dy        mouse-dx
old-button
/bandit@F2000000/ohare@10/via-cuda@16000/pram@0,0
PROPERTIES:
name                    pram
device_type             pram
/bandit@F2000000/ohare@10/via-cuda@16000/rtc@0,0
PROPERTIES:
name                    rtc
device_type             rtc
METHODS:
set-time        get-time        close           open
/bandit@F2000000/ohare@10/via-cuda@16000/power-mgt@0,0
PROPERTIES:
name                    power-mgt
device_type             power-mgt
/bandit@F2000000/pci106b,1@B
PROPERTIES:
name                    pci106b,1
vendor-id               0000106B
device-id               00000001
revision-id             00000003
class-code              00060000
min-grant               00000000
fast-back-to-back
reg                     00005800 00000000 00000000  00000000 00000000
/bandit@F2000000/ATY,BlueStar@E
PROPERTIES:
vendor-id               00001002
device-id               00005159
revision-id             00000000
class-code              00030000
interrupts              00000001
min-grant               00000008
subsystem-vendor-id     00001002
subsystem-id            00000908
fast-back-to-back
AAPL,interrupts         00000019
AAPL,slot-name          B1
fcode-rom-offset        00000000
EDID                    00FFFFFF FFFFFF00 04721100 06340082 14120103 682F1E78 2EC585A4 59499A24
                        125054BF EF008180 8140714F 9500950F B30081C0 A9402139 9030621A 274068B0
                        3600D928 1100001C 000000FD 00384C1E 5210000A 20202020 20200000 00FC0041
                        63657220 58323233 570A2020 000000FF 004C415A 30393034 37333631 300A00CB
ATY,Flags               0717029B
ATY,RefCLK              00006978
ATY,MCLK                00028870
ATY,SCLK                00028870
width                   00000320
height                  00000258
linebytes               00000400
depth                   00000008
display-type            43525400
device_type             display
character-set           49534F38 3835392D 3100
iso6429-1983-colors
reg                     00007000 00000000 00000000  00000000 00000000
                        02007030 00000000 00000000  00000000 00020000
                        42007010 00000000 00000000  00000000 08000000
                        02007018 00000000 00000000  00000000 00010000
name                    ATY,BlueStar
model                   ATY,RV100
ATY,Rom#                3131332D 38353530 352D3131 3000
ATY,Card#               3130392D 38353530 302D3030 00
ATY,Fcode               312E3836 00
driver,AAPL,MacOS,PowerPC
                        4A6F7921 70656666 70777063 00000001 B948891A 00000000 00000000 00000000
                        00030002 00000000 FFFFFFFF 00000000 0000C38C 0000C38C 0000C38C 000005B0
                        00040400 FFFFFFFF 00000000 00000EE8 00000EC0 00000B09 0000C940 02010400
                        FFFFFFFF 00000000 00000000 00000000 00000522 00000080 04040400 00000000
                        FFFFFFFF 00000000 FFFFFFFF 00000000 FFFFFFFF 00000000 00000004 00000027
                        00000001 00000140 00000158 000004F0 00000001 00000003 00000000 00000000
                        00000000 0000000D 00000000 00000000 00000010 00000000 00000000 00000012
                        0000000D 00000000 00000022 00000000 00000000 00000005 0000001F 00000000
                        ... 0000D449 bytes total
power-consumption       00000000 00000000
assigned-addresses      C2007010 00000000 88000000  00000000 08000000
                        82007030 00000000 80820000  00000000 00020000
                        82007018 00000000 80810000  00000000 00010000
METHODS:
close           restore         draw-logo       write           open            set-depth
disable-videomode               enable-videomode                show-modes      set-mode
mode#           ddc2ci-monitor-off              ddc2ci-monitor-on               ddc2-get-byte
ddc2-send-byte  ddc2-set-stop   ddc2-set-start  read-rectangle  draw-rectangle  fill-rectangle
get-colors      set-colors      color!          color@          dimensions
/bandit@F2000000/pci1011,14@11
PROPERTIES:
vendor-id               00001011
device-id               00000014
revision-id             00000011
class-code              00020000
interrupts              00000001
min-grant               00000000
fast-back-to-back
AAPL,slot-name          E1
name                    pci1011,14
reg                     00008800 00000000 00000000  00000000 00000000
                        01008810 00000000 00000000  00000000 00000080
                        02008814 00000000 00000000  00000000 00000080
                        02008830 00000000 00000000  00000000 00040000
assigned-addresses      81008810 00000000 00000400  00000000 00000080
                        82008830 00000000 80840000  00000000 00040000
                        82008814 00000000 80800000  00000000 00000080
 ok
This is with line wrap enabled.
There are some other differences in that I put back R133, and have drives connected for testing to see if adding a custom alias for the Radeon 7000 helps with the crashing while running RAVE accelerated games that the 6500 is known for.(and we have some other thread somewhere about)
Code:
0 > dl  ok
A >   ok
Something weird happened with the dl command - 10 items were placed on the stack (according to the A > prompt)? Did you paste something different than before? In a case like that, it may be better to paste normally without the dl command so you can see what's happening after each line.
The corrected output in your new dump adds some missing info for Radeon 7000 (Subsystem, minimum latency, Interrupt pin, Expansion ROM address, Power Management capabilities) and the Ethernet controller (Interrupt pin, Expansion ROM address):
Code:
00:0b.0 Host bridge [0600]: Apple Inc. Bandit PowerPC host bridge [106b:0001] (rev 03)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
	Latency: 32, Cache Line Size: 32 bytes
00:0e.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] RV100 [Radeon 7000 / Radeon VE] [1002:5159] (prog-if 00 [VGA controller])
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] XVR-100 (supplied by Sun) [1002:0908]
	Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32 (2000ns min), Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 255
	Region 0: Memory at 88000000 (32-bit, prefetchable) [disabled]
	Region 1: I/O ports at 0400 [disabled]
	Region 2: Memory at 80810000 (32-bit, non-prefetchable) [disabled]
	Expansion ROM at 80820000 [disabled]
	Capabilities: [50] Power Management version 2
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	00007010:88000008.f8000008 Region 0: Memory at 88000000 (32-bit, prefetchable) [size=128M]
	00007014:00000401.ffffff01 Region 1: I/O ports at 0400 [size=256]
	00007018:80810000.ffff0000 Region 2: Memory at 80810000 (32-bit, non-prefetchable) [size=64K]
	00007030:80820000.fffe0001 Expansion ROM at 80820000 [disabled] [size=128K]
00:10.0 Unassigned class [ff00]: Apple Inc. O'Hare I/O [106b:0007] (rev 02)
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR+ INTx-
	Region 0: Memory at f3000000 (32-bit, non-prefetchable)
	00008010:f3000000.fff80000 Region 0: Memory at f3000000 (32-bit, non-prefetchable) [size=512K]
00:11.0 Ethernet controller [0200]: Digital Equipment Corporation DECchip 21041 [Tulip Pass 3] [1011:0014] (rev 11)
	Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32
	Interrupt: pin A routed to IRQ 254
	Region 0: I/O ports at 0400 [disabled]
	Region 1: Memory at 80800000 (32-bit, non-prefetchable) [disabled]
	Expansion ROM at 80840000 [disabled]
	00008810:00000401.ffffff81 Region 0: I/O ports at 0400 [size=128]
	00008814:80800000.ffffff80 Region 1: Memory at 80800000 (32-bit, non-prefetchable) [size=128]
	00008830:80840000.fffc0001 Expansion ROM at 80840000 [disabled] [size=256K]
Code:
/PowerPC,603@0
PROPERTIES:
name                    PowerPC,603
device_type             cpu
I would put the text in a zipped attachment unless you really want the text to be searchable by the forum?
According to dump-device-tree, restoring R133 changed the clock-frequency from the overclocked 300 MHz back to the original 275 MHz. No other significant changes except you updated the screen devalias to point to the Radeon 7000, changed auto-boot? to false, set use-nvramrc? to true, and set nvramrc to
Code:
devalias screen /bandit/ATY,BlueStar@E
cpoke 0a7 0f3000032
cpoke 093 0f3000033
cpoke 03e 0f300003a
The Gazelle ROM (Open Firmware 2.0.3) has fcode for ATI device ID 0x4754
so the answer to my question of "does a Gazelle ROM contain a ATI Rage Pro fCode image" would be a No then
worth keeping that in mind then that its likely even once the ATI Rage Pro is made to actually appear properly on the PCI bus, it wont actually work until theres suitable fcode in place for it
I'm having fun with copy&pasting from different sources. Feel free to facepalm whenever you're ready. :)
If I copy the script off the website you have hosting it... I've managed to make that not work reliably. More on that later. If I download that hosted text file it does work.(hint: because of how I select it) And then also adding in testing with middle-click paste and terminal settings.
When a paste didn't work I don't really have a clue if it's a terminal setting(came up before with a different program, I think, but now I'm questioning everything) or if it's the contents of the paste. At least with Konsole(I'm running Fedora KDE) I know it works if it pops up a dialog notifying me that I'm about to paste hidden control characters.
So there has been some playing there. I guess I should have expected it to go somewhere even if it doesn't look like it worked. :P As long as it didn't break anything or trash the output, heh.
I have investigated and upon closer inspection with a hex editor it appears that while copying the script, say, from one text file to another I managed to miss the "04" at 0x7A7 at the end of "lspci for Open Firmware 60.txt", which I understand to be your Ctrl-D end transmission control character which dl is looking for.
Copying off the website carefully retains that "04" and it works even though that added four spaces"20" before each line. Carefully copying from another text file also works.
So, a learning experience, or trap for young players, as they say.
I have a habit of copying commands and scripts into a text file and adding notes for the future when I forget what is what, and that appears to have been a significant portion of my problem. Just to be clear this isn't an issue with anything you have done, you explicitly stated that there was a control character at the end of the file.
Should be the other way around, 10642AC0 before, 11E1A300 after, and 225MHz(D693A40 I'm guessing?) from factory.
Anyway, glad to have that copy&paste situation dealt with! 🤣 Hopefully I don't need to repeat that mistake again.
Yup, the dl command doesn't give much feedback except for a reminder at the beginning in later versions of Open Firmware to press Control-D to end the download. The lack of feedback makes the dl command be able to receive characters faster (because it's not echoing characters to the console).
Oh, right. The first dump was 10642AC0 = 275 MHz. Your first description of your pm 6500 in this thread said it was overclocked to 300 MHz so I thought the first dump referred to that. But I see that you later posted removing the R133 to get 275 MHz which must be the state represented by the first dump which was made after that. Then restoring R133 gives the result in the second dump 11E1A300 = 300 MHz.
Been studying up on the TAM, It's appear to be a stock 5500 board, the only difference (but for ID resistor setup) would the unpopulated SCSI port connector. SCSI devices internal and external DB-25 port are connected through that crazy I/O daughter board at bottom that hides the missing connector and the Machine ID Resistor Setup.
Thread was TLDR as not all that relevant to my research, so searched "SCSI" finding no hits outside of code listings. External SCSI
Thought I'd mention it because haven't seen my observations reported anywhere. Thinking about what's under the metal RFI shielding over the other I/O ports then aligned with CCSI, has anyone seen a rear view? WAG would be that they're aligned in the SCSI port on something like
Has anyone found a difference besides what's been documented in this thread? I'll start a dedicated topic on the crazy bi-directional, three layered port I/O connector setup
