I wonder if the video driver you are using for your card will finally fix my graphics problem with Hoyle Classic. Mine only seems to like VGA 3.0
I suspect it was a reasonable number, since in1992 (the date of the manual?) the 240MB drive was towards the upper end of what people would have had.So the manual is bull? Wonder where they got the 100MB max partition from.
Are the RAM chips failing on the OrangePC card (even though it passes memory)? Software? Or is DOS just being DOS?
It does (fortunately). Let's hope the retention tabs aren't brittle. I wonder what the max RAM is on the 486? I have about 10MB currently on the card.Surely the Orange 486 board has user replaceable memory
4 Slots
OrangeCard in IIcx. slowwwwww on Dos, but surprisingly fast in win3x.
So you’re recommending I should go to 16MB total? Any particular brand of RAM sticks to lookout for?4 x 4MB would be nice.
It’s currently being used to connect my SB-2770 Sound Blaster card to the OrangePC.Love how yours has an ISA slot!
