MDD Cache speed
indibil
Hi, I've been trying to view the cache speed on my 2x1.42GHz MDD with OS9 and Gauge Pro, but it doesn't show any information about either L2 or L3. I can't find any app that gives me this information.
Is there a version of Gauge Pro for OSX? Or what app could show me the L3 cache speed, or at least the ratio?
I've been told it's in a register called L3CR, but I don't know how to access this register.
Thanks.
Try PowerLogix CPU Director? There's a Mac OS 9 version and versions for some earlier versions of Mac OS X.
Performance Tools/CHUD/Hardware Tools has a program called "Reggie SE.app" which lets you view registers.
Thanks for your help. I finally found a version of CPU Director that showed this information in the MDD under OS9, and it wasn't the latest version.
I verified that the cache ratio was 6:1, and the cache chips support up to 300MHz, so I decided to change the ratio to 5:1 by modifying the EEPROM. I've summarized it here:
https://rosysumenteinquieta.blogspot.com/2025/07/acelerar-la-cache-en-un-g4-mdd-dual.html
I hope with this information we can change the cache ratios as we wish.
Do you mean the latest version doesn't run in Mac OS 9 (i.e. it's for Mac OS X) or that the latest version that runs in Mac OS 9 did not show the information? What are the versions that didn't work and the versions that did?
Under OS9 only the CPU_Director_1.5f5 version worked for me, the others gave me an error when opening the application.
