Is this a Sync on Green Issue? MacIIsi with an AD-A205 adapter
kjoh
Is there a combination of DIP switch settings that will work? Tearing my hair out here.
I've tried with a couple of different LCDs. Sometimes I get no image at all.
Funny, I let it boot up, and now it's almost normal. Except that it seems to fade back and forth, and now it's green again. Set to 110010. Will try some more.
I was using a Twin Turbo Graphics card with a VGA display, and it did this, there was a Sync on Green toggle in software, that fixed it. A similar thing.
I could be wrong, but you're using on board video from a IIsi, it's going to output a sync signal on green. Unless your LCD supports sync on green, you'll have some issues. It's possible the green tint is due to that sync signal riding on the green channel and causing the LCD to confuse it with the green signal. You should check what your LCDs support, not all support sync on green.
Hmm, are these open source? I find it daunting to order from the states, with exchange, duty, shipping. Before you know it, I've spent $100 on an adapter.
