Mac IIci battery bomb - trying to fix it
Hi,
I recently got a IIci with battery damage, it didn't look that bad compared to others I have seen online, so decided to try and get it working.
I have put wires to fix like 4 obvious broken traces in the battery area, replaced the CPU because the old one had 6 broken legs, and removed a couple of the ROM DIPS for cleaning, but sadly it won't chime on start up. all that on top of the standard full recap.
Current status is, I push the power button, it powers on like it should, have tested 12v and 5v in different points and both seem to be fine, but there is no chime, just the usual crackle on the speaker, and the weirdest on screen pattern.
Memory has been tested on a different Mac and it's good, same with the power supply, it's out of a working IIci I have.
Wonder if anyone has seen this before, and any ideas on what to do next will be much appreciated.
I'm not an expert on electronics or anything like that, I started some months ago buying old broken Macs and fixing them, mostly recapping and simple trace related stuff, just for fun and to learn about it, so far loving it. Feel free to talk to me like if I was 5yrs old.
Well, after fixing 3 more traces, I managed to get it to chime, followed by CoD, but only if using a custom ROM SIMM, the original ROM still shows the same display pattern no matter what. I'm pretty sure the CoD is happening after the RAM test, if I use the custom no RAM check ROM, it gives the CoD quick, if I use the stock ROM (in the SIMM) then it takes longer to give the CoD, which leads me to think something is wrong after the RAM check. I tried other RAM SIMMs I know are good, a lot of them, all the same result.
Latest on this, more traces fixed, on board ROM works now, still normal chime followed by CoD after checking RAM, black screen. Will really appreciate some advice on what to check next, all address lines and data lines from ROM seem to be ok now.
There is no extra video ram so check all Simm sockets contacts ...
Well, yeah look like the socket contacts are not great, I found 4 ram SIMMs in one of my other Macs that actually worked! I know all there Simm s are good because I have tested them in other Macs. I decided to push the Simm socket contacts out a little bit, try to force them to make better contact with the Simms, and that definitely helped, now it's using the original 4x4mb Simms I was trying to use from the beginning, no issue.
Thanks for making me have a mother look at this, I was almost about to give up!
