Need help on this one gang. I'd like to develop a circuit to use the OEM board's potentiometers to act as the four Menu Buttons on the LCD Controller's input board if possible. Don't need power switch, when system powers up the screen turns on, power down and it's off.
- rotation of wheel to minimum setting blips one momentary switch input for SOURCE
- rotation to maximum setting blips momentary switch input for MENU
- right side pot would be + - inputs
- repeated rotations from neutral to max or min would be same as hitting momentary switch on control board repeatedly
- any setting between max/min ignored as neutral (near max/near min?)
I've probably got cubic to install or solder a hat down to the CM4 I/O board for the purpose. CM4 won't be doing anything else while I may be adjusting the LCD. If not I can add another RPi Pico or Arduino into the mix for a total of four CPUs on board.
So much of this project is above my pay grade, but plugging away one bit at a time. Any help much appreciated.
