@kdrone if you have the MDD there is a single screw securing the left tab of the modem connector case. Remove that and pivot it clockwise 30 degrees and pull it away from the case wall. Dealing with the existing wire is another issue, I ended up cutting it. Removal of the processor heatsink is not required but makes this much easier.
