Fantasy M88100 Macs
everything would be as it was in the mid 90s, but faster
I don’t know. I think I’ll take SATA and USB over SCSI any day of the week. Also, at least present day macOS is stable. I think mid 90s but faster would just mean you see system bomb errors even quicker. 😃
Well, sure. I didn't necessarily mean it literally, of course!
We can still enjoy many of the technological improvements we've had in the years since, but I just wish that GUIs in general could've stayed more or less as they were (i.e., modern MacOS that still looks like Classic).
But most importantly, I wish we could have the simple, 90s internet. The modern internet is fine and good, but it's becoming too complicated, invasive, and increasingly divisive (I won't go into more detail because politics).
c
I think @joshc is also writing partly in jest. I think most of the software reliability issues in the 90s were due to:
  1. Cooperative multitasking instead of preemptive (obviously).
  2. Relatively poor software standards - software disciple has improved a lot.
  3. Just lots more work applied to old and new software squeezing out bugs.
  4. Proper protected OSs and applications (biggest classic Mac OS mistake, besides sticking flags in addresses <facepalm> was to run it in Supervisor mode, even the QL didn't do that - did the ST and Amiga? I guess the Amiga didn't).
All of these applied to old software would have had the same effect - arguably, in an earlier time-frame too, because er, smaller software = less to debug.
Since FDDs & HDs by their very nature were serial devices, the dumb thing IMHO was to place the deserialisation close to the peripheral instead of close to the CPU.
Anyway, seems like ATA and SCSI kissed and made-up through SATA and SAS:
Super-ironically, of course, parallel ZIP drives actually talk SCSI over the parallel port!!!
Even before that, ATAPI drives for PCs (CD and DVD-ROM, Zip, probably a few other things) used SCSI commands sent over an ATA physical transport. As often happens in the computer industry, "baroque but cheap" wins.
With respect to software reliability, proper protected OSes are 90% of the improvement, and improved tooling (Valgrind, Coverity, the Clang -checker builds, VTune, etc) is most of the rest. You could have a cooperative multitasking OS with memory protection and process separation and it'd be pretty much as reliable as modern OSes in daily use. The classic Mac OS suffered far more from memory overwrites and related crashes than from applications refusing to give up their time slices.
As far as M88K, it'd be cool if the ROMs from the original "RISC LC" ever showed up. That could definitely be supported in MAME.
It's out there - the computer history museum interviewed... The developer with it on the table. I can't remember their name :( sorry.
Not sure if the developer has it or the museum.
Cool, that's what I've just been listening to. I hadn't remembered it was called the RLC, but I listened to all of the videos on my walks last year - I found them fascinating - hence that's why I started this topic, because essentially it's the genesis of the PowerMac. It's interesting therefore that I chose R41, R51 and R61 as the product names for the fantasy 88K-based Macs. Though more recently I've been trying to think about what the name for the product family could have been. So, by the time Apple released the PowerPC Macs, it was fairly obvious they were going to be called PowerMacs and part of the clue for that is that the laptop range had been titled PowerBook since 1991 just after (I believe), the PowerPC development announcement.
So, in the alternative history, there's no PowerMacs, because Apple didn't choose PowerPC. That means there's also no PowerBooks. I went through a few possible product family names:
  • TurboMac. PC compatibles were using this kind of prefix already.
  • DynaMac. The ultimate objective of Macs was to create Alan Kay's mythical DynaBook and 'Dyna' might be a good name, because they would have a fairly dynamic performance: slower under emulation, but much faster running native and it sounds impressive. However, it also means they'd called the laptops DynaBooks which I think is too pretentious even for Apple.
  • RiscMac. Too technical, also I wouldn't have it conflict with Acorn's RiscPC series even though that'd be a bit in the future.
  • MotoMac. But the 68K ones are already Motorola-based and tying the name to a specific company wouldn't be Apple.
In the end I thought NuMac™ might be plausible (though it is a precision engineering company in the UK). Macs at the time still used NuBus so that would fit. NuBook sounds reasonable. 'Nu' implies "New", but that doesn't mean everything is faster.
So, then I started wondering if Gary Davidian had the original source code for the RLC ROMs or if it was possible to see the RLC in action? He seems like a decent guy, what happens if we contact him?
OK, I've emailed him! I'll see what happens!
They might have just gone with the Macintosh III?
I've heard that Apple was superstitious of "III" after the fiasco with the Apple III. LC III allegedly got through on the basis that it was two words before the dreaded III instead of just one, but "Macintosh III" was specifically skipped on the way to "Quadra".
Ah, fair enough. Macintosh Quintra it is then.
The name powerbook is not powerpc-related as far as i know
Possibly true, but the first PowerBooks appeared in October 1991, and the letter of intent for the PowerPC Alliance began in the summer of 1991, and formally cemented on October 2, 1991. The Book bit is easy to explain, because of the DynaBook concept, but it's hard (for me) to explain why Apple would call the range PowerBooks if they hadn't intended to keep the name in anticipation of PowerPC Macs (and importantly, PowerPC laptops).
M88K Emulation Perfomance
Earlier in the thread I tried to imagine what the M88K emulation performance might be like. I came up with about 10 cycles minimum per emulated instruction, using the 2-word table approach actually used by the PowerPC emulator. Is this credible? To estimate this I looked up the SpecInt performance of M88100 computers (basically the AViiON systems by Data General); compared that with SpecInt for early PowerPC and scaled it against early PPC emulation performance.
System/CPUMHzSpecInt92Ratio
DG 4100/881002517.40.28
IBM 250/MPC6016662.61
HP 425t/680402512.30.20
Compaq DkPro/80487SX2514.2
So, if a PowerMac at 66MHz was similar to a Mac Iici/Cache at 25MHz. Then from this LowEndMac link, such a Mac Iici was 4.3x faster than a Mac SE, then a 25MHz 88100 M88K Mac would possibly emulate a 68K at 1.2x the speed of a Mac SE, which essentially ran at 7.5MHz. Now we can calculate the number of M88K clock cycles, since the minimum instruction = 7.5/4 = 1.875 MIPs, so 25MHz/1.875 = about 13 cycles per minimal instruction. It's not really possible to use the full 0.175MIPS/MHz (vs 0.25MIPS/MHz), because my emulator draft doesn't handle more complex instructions (and addressing modes: loads and stores increase emulated performance, decoding decreases it, multiplies and divides would be faster [but are rare], FPU much faster, Barrel shifter would emulate at 10c for all immediate shifts, but 14c on average for a 68000 [so immediate shifts would emulate on average like a 35MHz 68000 !!!] etc).
One final note: I've included the 68040's and 80487SX SpecInts on the bottom line. The 68040 aims for RISC-like performance, and the 88100 is only 40% faster at 25MHz (like a 35MHz '040), but we can see that it's already losing out to Intel. Given the emulation hit and the relative cost of an 88100 chipset, could an M88K Mac even make sense? - Only for specialised applications IMHO, but that was the assumption at the beginning.
Don't forget that the SE wasted CPU time while the video / audio was accessing RAM. So the SE doesn't get the performance of the full number of clock cycles.
The 88k Mac wouldn't suffer from that because they'd moved on from that sort of architecture. (Yes, the PowerPCs used RAM for video, but it used some sort of DMA to improve efficiency - yes it used CPU cycles to move data, but was able to do more while the video was using RAM)
This is conspiracy-theory level thinking, and assumes a competence in Apple's internal communications that there's no evidence they have ever had. They obviously were totally happy to rename things when PPC hit in the desktop space, why wouldn't they have been in the laptop space? Coincidence of dates is not, in itself, evidence.
Well, I have to start somewhere ;-) .
Also true.
I thought they'd basically eliminated the cost for that with the Mac SE vs the Mac Plus, but I could easily be falling victim to Apple Marketing here!
Interesting and encouraging.
I was trying to find the figures but failing - basically they doubled the size of the shift register so that it reads two words instead of one on the older design. Instead of 50% access during a scan line you get two CPU accesses for every one video... I think it was. Then you have to account for vertical and horizontal blank that improves the ratio.
But yes, better than the plus, but still not that good really. A lot of lost time.
If you're really interested I could try to find last time it was discussed, or probably calculate it again. Thankfully the lack of cache makes it a simple calculation!
It is interesting! I thought it might be that they used faster RAM on the SE, but cleverer hardware is less unimpressive ;-) . So, were SE ROM fetches also stalled for video? Using alternate phases for video access was quite common on 6502 computers. I guess the calculation is of the order: 60.15Hz x 512 x 342 / 16 x 4 = number of cycles used for video = 2.6M. So, out of 7.5MHz, that's: 35%, ouch, but I'm not considering the proportion of internal CPU cycles. Were they inspired by ZX81 video or something ;-) ?
I.... Think it could possibly still read ROM? I think I read that. But I haven't seen it while reading just now. I'll let you know what I find.
Do you know how long it would take to read two 16bit consecutive words from RAM?
