How do you get to that conclusion? I see that patch as an underclock...
Looking at it, R1-R4 are either open or closed by 0 ohm, so I suppose R5-R8 are pull-ups or pull-downs and the optional R1-R4 invert the value.
Assuming they are in order for PPL_CFG[0:3] or PLL_CFG[3:0] and depending is they are active-high or active-low, the value is either 'b0101 or 'b1010. Those would be either 6.5x or 4x, and 6.5x produces values way too high with the usual bus in those machine, so we can assume it's 'b1010 and 4x. I think we're in agreement on that.
However, R2 would be either bit 1 or 2 - changing R2 would produce 'b1110 or 'b1000. The first option is 3.5x so would underclock (safe), and the second one is 3x (even more underclocked, probably also safe, though unlisted as the bus speed is likely too low).
(I didn't look at the 604e datasheet in details so would have missed something).
