Anyone up for some IIcx troubleshooting assistance? We have clocks but no activity...
That doesn't meant anything.
Unloaded can produce bad voltages from a good PSU and good voltages from a bad PSU.
Yeah. That why im making a molex cable.. i can then jumper pin 10 to pin 9 to manually power it on and selectively supply the 5v and 12v to the board and put an amp meter on it to check the load.
DO you know how much current the board SHOULD be pulling on the 5v and 12v rail?
Hum. It might be in the hardware reference book but I'd have to research. It is for the Mac II, but the easy thing to say is look at the ratings written on the power supply. Less than that, minus the allocation for any empty NuBus slots.
Yeah that is exactly what I did. For now. But the 5v out on the psu says 12A and 1.5A for 12v. 15A on 5v has to be over kill. I bet it’s more like 1.5 to 2a if that.
Old computers ran almost everything off 5V, even an old hard disk could use 2A on 5V.
12A is the maximum, but isn't an insane amount.
Tested all the RAM with the Mac plus. All but one SIM was good.
While using the bench ATX supply under load on the board the voltages are 4.6v on 5V rail and 12.8
no load = 5.1v and 12.5v
12v increases in voltage under load.
I should use only bank A full of SIMMS I suppose
Only SIMMs up to 1MB will work in the Plus, I thought you were using Plus SIMMs in the IIcx, not IIcx SIMMs in the Plus.
I took the simms out of the plus and set them aside and then tested all of the iicx simms I have.
They are 1mb simms totalling 4mb per bank which is the maximum amount you can put in a Plus.
So now the IIcx has 4 1mb known good simms in bank A and bank B is empty.
OK OEM power supply is good,. the problem is the +5 feed to pin 9 to turn it on is too weak causing it to collapse. if i disconnect that pin and jumper it myself to pin 10 then the board comes up (with the sad mac). while the board is running if i connect that back the power supply collapses again even while i am jumping pins 9 and 10 together.. if i add the trace on the board to pin 9 it kills it.
so its like the trace to pin 9 on the board is pulling it low.
WIth the power supply running trace from board to pin 9 disconnected and me jumping 9 and 10 together, the board is running and when i check the voltage of the trace on the board to pin 9 it is .5v and should be 5v.
Ive let the board run for 30 mins or so and nothing is hot to the touch. the Nubus chips are a little warm. Probably the warmest ones on the board.
I fixed the power circuit issues. So now the soft power and original PSU are working. Still tracking down the chime of death cause.
Quick question. Does a healthy IICX make a normal startup chime if it has ram but no video card in the NuBus slot?
Would like to know if I can put video aside while troubleshooting. Haven’t found any solid answers online though.
Thanks for confirming. The problem is I don’t know what the state of the video cards are so I want them out of the loop. With none card in there’s no difference. Same death chime the instant I power on and no activity on the display. With the other card there’s no chime at all. So I plan to resolve the startup chime without the cards first.
Ok good to know and now if I knew what exactly the P.O.S.T checks. I know it checks ram. My SIMMs are tested good. I am suspecting it’s the MUX chips below the SIMMs
Just got a happy chime :D
Bad UJ3.. it looked pretty bad.
I went ahead and lifted UJ1,2, and 3 and cleaned the pads up good and im replacing all 3 with new ones now.
After that I'll see what the NUBUS and video loos like 🤞
