broadATX
b r o a d ATX for Macintosh II, IIx, and IIfx broadATX is the latest product from Anserine Machines, and aims to provide the same ease of use as our original beigeATX. broadATX was designed specifically for the Macintosh II, IIx, and IIfx series as a drop-in upgrade. It permits a suitable*...
anserine.co
Hello everyone,
I'm pleased to announce that my latest project, broadATX, is now available at the Anserine Machines store.
broadATX is a simple, drop-in adapter for the original Macintosh II/IIx/IIfx series that adds support for ATX power supplies, no soldering required.
broadATX supports the the original soft power implementation on systems with undamaged startup circuits.
For those with existing soft power issues, a set of 'Force' pins are exposed. These trigger the ATX supply directly, and the supply will remain active so long as they are bridged.
broadATX ships fully assembled and ready to install from St. Louis MO. Thanks to everyone who purchased a beigeATX in the past - your support enables projects just like this.
