Hey all,
I've posted this in tinkerdifferent as well but have only got one person to help out some so trying over here...
Ive been troubleshooting my old super corroded Mac Iicx.. so far ive managed to get the power circuit working so pressing the power button fires up the power supply and the board is receiving power. The LED is lighting and I have all the correct oscillator and clock frequencies that I have seen so far.
Other than that the board is dead. I have pulled the sims off the board for now while just truing to see some square waves across there address and data lines.
What I have seen so far:
MPU:
Reset, halt, ds, as, r/w all go high on power up
I have a 16mhz clock at E1 on the 68030.
Data lines are sitting at 1.5v
Address lines are low
UG11 has both 30 and 40mhz clocks
Uf11 pin 5 has 16mhz clock
FPU clock is also good
Glue chip pin 17 has a 30mhz clock and pin 18 has a 16mhz clock.
Pin 72 has a 782khz via clock
Y1 is 16mhz
I am stuck now trying to figure out what to check next to see why theres no activity on the 68030.
Any suggestions would be great.
** The board has been re-capped, scraped, cleaned and all broken traces I have found so far have been fixed.
Thanks,
-Tavis
MPU:
Y1 is 16mhz
Thanks,
-Tavis
