If you have a "red" and "yellow" floppy ribbon, try both and see if there's any change.
no sorry, was checked already before my first post.the switch is working ok.
Did you ever figure out this issue? I have the opposite problem - the eject motor never gets 12 volts on the brown wire to start the eject cycle. If I momentarily jump from the yellow to the brown wire the motor will do the eject cycle so it seems both of our problems are upstream of the eject module.tried to fix it this week-end, wasn't able to do so. the eject motor is receiving constantly 12 volts from the bown wire so motor is spinning all the time.
replaced both transistors... don't know at this point what can be wrong, used another Plus for a test, same issue.
