Hello!
Today while sitting in meetings at work I strolled across facebook marketplace when I saw "Apple Computer"
Thought to myself that's a Apple ///, this can't be real
Contacted the person, offered $250, they said come get it.
I drive an hour an a half, pull up to a walmart, get my Apple /// and head back home. Angry Mac in passenger seat
I get home, lay everything out.
2x Apple Disk ///
1x Apple ///
1x Monitor ///
2x apple write /// floppies
Pics of floppys:
This odd film/plastic modified is on both of them, worse on the one with the circle. It's physically burned into the Disk III sadly. But hey! It's character!
Tried hand washing, scraping, soap, purple power, about everything and the brown will not come down. The main dirt part next to the burn circle did though.
Insides are neat perfect shape, just very very dusty and in need of a good cleaning.
I would like any suggestions possible on that if I can, if not it's character!
On to the apple ///, it doesn't look to bad on the outside
I open it up to find this
Is that a hornets nest on the side? Stuck into it? I can't see the board because there is so much dust? Bugs everywhere?
Pretty nasty
Thankfully no hornets!
Looking closer at the board it's all dust.
Gotta get the board out and clean it.
Can't be that hard.
All screws out but one and the last one breaks in half and case lid comes off.. that's fine I guess, it was rusted.
Open the back
Not the best, not the worst. A bee and a extra treat, for me?
Start taking the screws off the board and 2 look like this..
The first one I get out just fine. This one though, I spent over an hour on.
I touched it and the whole screw fell apart.
I tried different screws, I tried different methods, wd40, pliers, everything.
I cleaned the screw down as much as I could.
Took a kitchen knife and made a slit for a flat head.
Finally! Came off. Board off!
Have began to clean off some of the areas of specific dust. Love not being able to read anything then it becomes clear after cleaning off.
The top of the case has rust. Where it covers the board, that has a vinager soak overnight.
This is where I stop for the night, will update more as I continue.
I will ask for some advice on the monitor, seems to usually come down to "clean it?" Need to do anything?
I thought it didn't work because it wasn't focused at first. Then I plugged in my c64 and it worked fine...
Spent an embarrassing amount of time looking at stuff for it.
Looks like I have a white phospher one which makes me very sad it's not green.
Now I have a amber, white but no green monitor. Damn.
Any tips for restoring the Apple /// Also appreciated.
Tips for cleaning this overly dirty board? Toothbrush and 91 IPA only seem to go _so_ far. I guess tooth picks work, but I'd use a whole box of a 1000.
Tips for actually cleaning the aluminum also or whatever the body it. It's so splotched and not so good looking...
Thanks!
2x Apple Disk ///
1x Apple ///
1x Monitor ///
Pics of floppys:
Pretty nasty
Can't be that hard.
Open the back
Thanks!
