Does anyone have a 7500 ROM SIMM and if not are there modern day programable ones?
found anything in the 7500 motherboard online pictures?
it's weird because it's a very common Mac model
If you find the code, I can check if I have it
Well most had on board mine is an EVT without on board ROM so what I want to do is find a simm from a 7300, 7500,7600, 8500, or 9500 so I can boot it. I hate to solder ROMs to an EVT board that had them simm based
yes, I understand, try to see if it finds the correct simm code
I’ll try ive been looking through what documentation I’ve found in my Vol 5 service guide (in the wiki section here) it talks about the ROM simm but not the number annoyingly
Might be worth looking in service manual pics if they haven’t. They often picture prototype boards, but may well be too low res to get the part number.
All of these SIMMs will boot my board if anyone has one PM me
Power Mac 7200/75/90/120/120PC
Power Mac 7215/90
Power Mac 7500
Power Mac 7600/120/132
Power Mac 8200/100/200
Power Mac 8500/120/132/150/180
Power Mac 8515/120
Power Mac 9500/120/132/150/180MP/200
Power Mac 9515/132
Maybe cross reference with a layout/picture to make sure its not the cache card.
Sadly they're all cache cards. Please forgive the messy mark-up, I'm on my phone, but you can see the silkscreen in this markup.
SIMM ROMs are really unusual in this era of machine.
@jajan547 Sorry I didn't see this thread sooner. I've been away from forums for a while.
Really TL:DR summary: Look for a module with four chips on board. The chips are labeled 341S0169, 341S0170, 341S0171, 341S0172. That will work, even if it is a PowerComputing Corp. (PCC) module.
If you can't find one let me know and I can probably hook you up. But note that I've been busy enough to not read the forum for most of a year and my response times are likely to be poor.
I can also manufacture any ROM you want, but then you're talking really long lead times: https://68kmla.org/bb/index.php?threads/pex-rom-project.23568/
The Power Computing Corp. ROM modules can definitely be used provided that pin 116 is tied High (5V) on the module. Pin 116 of the socket runs to the CE_ pins of the on-board ROMs, so tying it high on the module pulls CE_ of the on-board ROM chips high and disables them.
http://sphinxgroup.org/Apple_pinouts/Firmware_Module_Pinout.txt
Oh, but that doesn't matter for you because you have no on-board ROM chips. So, you can just install a PCC ROM module and it will work. Plus, IIRC PCC ties pin 116 high. They just copied the Apple design.
Except... PCC also sold a NuBus PowerMac clone and the ROM for that will not work. You need any of the PCC ROMs that were not made for the Power 80, Power 100 or Power 120. More on identifying ROMs below.
TL:DR stuff... (note, X500 refers to the 7500, 8500, 9500; does not refer to the 5500, 6500 or any other machines)
The following Apple machines used the same firmware (ROM) module circuit board/pinout: NuBus PowerMac, PM7200, X500, X600, ANS, Beige G3, PEx. Of course the **code** installed on the ROM chips was different for each family of machines, but the hardware module remained the same.
The firmware used on the PM7500 is $77D.28F2. There was actually an earlier version, $77D.28F1 (IIRC) and that might be most appropriate for you, as that was the earliest I've found.
Note that $77D.34F2 (X600 original) and $77D.34F5 (X600 "Enhanced", AKA Kansas) will also work.
So you have these choices found on these chips:
$77D.28F1 341S0106, 341S0107, 341S0108, 341S0109
$77D.28F2 341S0169 - 341S0172
$77D.34F2 341S0280 - 341S0283
$77D.34F5 341S0380 - 341S0383
The first column is the ROM revision number reported in Apple System Profiler. The second column is the four Apple Part Numbers found on the four ROM chips used on the ROM modules, or soldered directly to the logic board. These part numbers are on the chips, not on the circuit board.
All of the PM7200 also used either the $77D.28F1, or the $77D.28F2.
$77D.28F2 is by far more common. I've only seen a very few examples of the $77D.28F1.
Every (non-NuBus) Power Computing module I've ever seen has the $77D.28F2 on board.
There were also various modules out there with EEPROM or Flash chips on board. Apple had some kind of reprogrammable module. It looks like @al kossow knows a lot more about it than I do. I've just seen a few examples over the years. I think the ROM module in the DigiBarn PEx machine looks like the modules that Al posted an image of.
This is amazing to hear! If you can make me a ROM that would be awesome I have no rush on it either but please do let me know. I'd probably go for the earliest version you've found if you can.
