need help to order correct parts, thank-you
I need some 74hc74, hc132, and f258 for some board I am working on. Can someone link a mouser product, or digikey so I can order correct ones. Would really appreciate it. Also, seem to have a hard time ordering correct axial caps. The 220uf came with really thick leads, or they are way to big lol.
@imactheknife - when you name your threads its worth considering how someone might be searching for it. Say what the topic is, what machine. For example "What suppliers should I source logic chips from in Aberystwyth". Remember to say where in the world you are when asking advice were your location matters.
ok, good idea! thanks!
