I've nearly got it working, but something's not quite right.
I'm missing something about bicolor LEDs. I've made a wire harness that I thought would work:
And it almost does. I bought a Red & Green bicolor LED. It has 3 pins. I AltaVistaed online and it said the middle pin is the common anode, then I run the red on one side and the green on the other. So I put two black wires on the middle pin, and then a brown wire for red and blue wire for green (those were the only colors I had.)
The problem I've run into is that the green is always on, then flashes off with HDD activity. The red works properly and turns on when I insert a floppy disk.
I want the green to turn on during HDD activity. Did I wire it wrong? Or is that how bicolor LEDs work?
