Hi, some friends and I have been testing upgrades with their G4 Cubes. I think I remember reading in some thread that some processor upgrades aren't compatible with VRM Upgrades, but I can't find it. We're testing with an ARTMIX VRM.
The Cube has the MC7447 patcher applied.
I have a Gigadesigns MC7447 processor at 1.6GHz, for G4 towers, not for the Cube, and to make it fit inside, I replaced the solid-state capacitors with LowESR tantalum capacitors, with the same final capacitance, and I adapted a copper plate to fit the Cube's heatsink. It's running at 1.6GHz at 1.3V. This processor, both with its original heatsink and with this copper plate, works perfectly in a G4 GE and a G4 DA after modifications. But it doesn't seem to work in the Cube.
It occasionally boots, but after a while it freezes. Most of the time, when I press the power button, the power LED lights up and then turns off, like when there's no processor, but the two motherboard LEDs are lit, DS1 green and DS2 red. And the three ARTMIX LEDs are lit, but it doesn't work. I put the original processor back in, and it works fine.
Has anyone adapted one of these Gigadesigns to a Cube and had it work? Am I doing something wrong?
