Need help to fix quadra 800
The board had a small amount of battery leakage. I have ordered new pieces. Only one I couldn’t order was a custom vls1 chip. It needs to leg repairs. I pulled that chip off but it snagged a pad. In the attached picture you will see no traces or holes where the pad was. Just curious if this is a ground pad and how to fix it. Thank-you, mark
Wow, made my morning:) thank-you
No problem!
No trace and no via means it's not connected to anything.
I did a bombed 650 board (same board as 800) recently and most of the N/C pads were gone, and a couple of the connected pads needed some repair. All worked fine when I soldered the IC back on (along with some other repairs in the same area).
Ok, just need to confirm if the copper around the postive is ok like this. I scraped around it to see why the little copper trace leading to one of the diodes wasnt connected. I want to put new battery holder on.
Probably needs a bodge wire, check continuity between the pad and where the trace leads to.
ok all my traces are connected, and bodge wires done. I got the chime on first power but forgot to plug monitor in. powered off, plugged monitor in, no chime. now no chime. I also notice that my reset buttons are non functional. could this be the issue or an issue??
Ok, any one have any idea what to look for?? Ni video, no scsi activity. Chimes with no error, reset buttons work, soft power works but cant do pram reset. I get a little static in speaker shortly after the chime which I think is not ok. Power supply has good voltages.
Do you have a full view of the chips near video out connector? Leads me to believe a VDAC issue. As for the sound it happens, Color Classics tend to have that issue as well.
Im not getting scsi activity either. I am not sure the order of how things go once you hear the chime.
I'd remove the ram and vram simms while testing. Wombat has both onboard.
After the chime, it does the memory test, then there should be a faint pop from the speaker, and then you should get video.
I am curious if the behaviour changes if you remove U63 altogether. I have a wombat board on hand that I'd be prepared to do such experiments on, but I have just moved house and all my soldering gear is packed away in temporary storage.
Edit: you should combine your/my posts about this from the other thread into this one, so that it's not confusing for other responders...
Soft power works, i get a small speaker noise but no video. I cant do a pram reset. Does u63 have anything to do with video?
I don't think U63 has any direct connection to video, but it is presumably somehow instrumental in the early boot process as evidenced by my board with the same symptoms.
Well, it can be part of the problem still. U63 was affected by the battery acid leak, two feet were corroded off. I had to dremal the chip and use some wires to reconnect it all. It may still be part of the issue I guess. I really dont wont to pull it off as all the fine soldering i did lol.. i dont have a spare u63.
What is this slot for? I traced one pin of u63 to it. I dont have anything to go into it. One before memory slots
That's a ROM slot, typically on early boards you see them because Apple figured if the machine had ROM issues they could essentially install a jumper and the new or working ROMs on a simm. Thus if the Jumper was on and the ROM simm installed it disabled the onboard ROMs and used the ROMs found on the simm. I personally wouldn't see that as causing your issues though because on most boards that slot is removed entirely.
According to the Guide to Macintosh Family Hardware 2nd Edition, the RTC (at least on previous models) also contains the PRAM, so it makes sense that it would be accessed early in the boot process...
On the other hand, the volume of the chime is stored in PRAM, so it must be reading that...
Ok will take a few snaps today. I did find some of the diodes by battery were not making contact through vias on other side so had to put temp bodge wire on where needed. Didnt change anything unfortunately as far as booting etc. the pram makes sense because I can’t even do a pram reset, so something in u63 must not be making a connection, or u63 is part dead??
