Much like LazarusNine, I had my own disaster.
Two issues:
1. Had my iron set for 650F and was using some solder tweezers (Hakko FX-8804-02) thinking it would be easier to get the SMD caps off. It was, but it left residue in between the pads. I think I got a little too rambunctious trying to clean off the residue and it looks like I exposed a trace. I think. Check out C4.
2. As far as the axial caps go... I've done this with through hole components enough that it should not have been an issue, but it was. I just couldn't clear of solder out of 3 those 4 holes. I have a fancy desoldering gun, but that didn't seem to do the job. (Seemed the tip was too big for these smaller holes? Normally not an issue when desoldering through hole caps.) Maybe I don't have the mojo I need for solder wick. I do prime it with solder to get it going... cleared one hole, but the others... nada. I have a cheap solder sucker that... surprise, didn't seem to do it for me either.
Note I do plan on putting this baby in the dishwasher. (no soap, no drying cycle) I'm hoping that will take care of some of that cap residue, and will be more gentle than me chipping at it with a solder tool and isopropyl.
Anyway... please take a look at these shots. Maybe it's not as bad as I feel it is. Maybe I should be publicly shamed. Learning on the internets and having fancy tools is really swell and all, but it's skills like these where I wish I could get time in person with someone who really knows how to do these things... especially when repairing these older boards. Even though I've successfully recapped one board, this hardly makes me an "expert."
Thanks again for any thoughts you have.
Two issues:
