I need a new PSU for my SE/30, and it would be best if I got a modern one that supplies more power than the stock PSU. Any idea what ARTMIX could be using? (I doubt they made a custom designed power supply just for the SE/30. It certainly must be an off-the-shelf model, I would think.)
http://www.artmix.com/hps_2009_EVO.html
There are two +12V outputs, one being for the SWEEP. I assume these are isolated? For why offer two +12V output's instead of one powerful +12V unless they are needed to be isolated (to avoid noise issues)?
I might be able to afford one PSU from ARTMIX, but I'd really like more than one since I have more than one SE/30. But at $200 a pop, that's too expensive, which is why I am posting here to see if anyone might know of a PSU that would fit inside the stock metal case and offer the same 4 outputs as the stock, but with higher current ratings.
It's amazing to me that despite all the hundreds if not thousands of us who own and love SE/30's, you don't find any "rebuilt" PSUs for the SE/30 for some reason (outside ARTMIX). That implies that nearly every SE/30 owner on this planet is either using a stock PSU, or possibly a recapped PSU (which would not put out more power than a new stock PSU, which isn't designed for that many add-ons). The reason I seek a modern PSU inside the stock metal PSU enclosure is to cover any power requirement, regardless of the add-ons I add inside (HDD, PDS cards, etc.) I therefore look forward to hearing your thoughts.
Thanks.
Thanks.
