DiskCopy + Basilisk II = Fail?
I have my Basilisk II setup running System 7.5.3 and I want to update it to 7.6.x. But DiskCopy seems to have gone on strike. Every version I've tried gives me this rubbish:
I'm using a Performa ROM, and there's a couple thousand choices for different models. Advice please?
This is the Disk Copy that you installed with 7.5.3? Was the virtual hard drive a pre-install that might be a PPC version? I don't know if that could matter for Disk Copy.
Nope, it's not the Disk Copy that came with 7.5.3. And the virtual hard drive is a boot disk I downloaded. It could be PPC, I'm not sure how to check though.
IPalindromeI... I don't think Basilisk can't run Disk Copy (that's a pretty bold slam...).  Juliet, it's the virtual drive you downloaded.  Might be worth bothering to set up a drive yourself.  (The inverted colors are apparently a function of the screenshot - this was the best I could do to invert them back.)
Yep.  I also have issues with 6.5, but that may be my build.  The above is 6.3.3.
Actually you may have hit it on the head with version 4.  I think the error I got may have been the same as Juliet's.  So Juliet, I'd try 6.3.3 first.
Some .bin files only extract (or whatever you'd call it) with Disk Copy, right?  Or would they generally also work with Stuffit?
I'm just conveying why I personally use Disk Copy on occasion.  But also only because it's usually bundled.  There are probably better programs for it.
Perhaps, but vMac can be configured with the Sony driver specifically so it'll work with Disk Copy.
http://www.gryphel.com/c/var/index.html
I run vMac with the Macintosh II ROM, color graphics, and sound with the Sony driver.  The sound really buggy, but it works well with software.
Which option are you talking about here? I see several options for tuning how the .Sony driver works with Disk Copy 4.2 images (IE, set it up to skip the header and update the checksum on exit) as virtual drives but that doesn't have anything to do with whether the running OS will itself will run Disk Copy 4.2 so far as I can tell.
I'm needing Disk Copy for the System 7.6.x install images I found. I'm needing to update the OS 'cause Toast seems to hate my setup and Virtual DVD-ROM/CD Utility apparently won't run on any version lower than 7.6. I'm trying to get a game CD image I found in .toast format to mount so I can install it and play.
Problem solved! DiskCopy 6.3.3 is running great, and I'm now emulating a Color Classic II running System 7.6. :D Now, do I want to upgrade to 7.6.1? That's the question.
Just FYI, 6.5 probably works on Sheepshaver - on my 8.5.1 partition I get an error saying 6.5 requires OS 9.1 or later, but I've never been able to find a working bootable copy of OS 9 for Sheepshaver (really odd issue - this includes versions I have installed on genuine Macintoshes).  Disk Copy 4.2 definitely works on vMac.
