Was this really necessary Apple? AAUI already supplies +5v for AAUI transceivers and has enough juice to power regular AUI transceivers using a simple pin adapter. Why do you need to make an external power brick?
Funny because I have an official Apple AAUI to 10BaseT transceiver with actual electronics in it that is a fraction of the size. IBM used the AAUI plug too, but called it "Mini AUI". What does the inside of that box look like?
Unfortunately it's ultrasonically welded so I can't open it without destroying the case. My assumption is you will find the AAUI-AUI conversion is completely passsive, along with a +5V transformer and a simple switching circuit driven by the mac's own +5v AAUI supply.
